Engine Questions
Old Mar 30, 2003 | 02:42 PM
92WhiteRS's Avatar
Engine Questions
Alright everyone, I have a few questions that some of you may help me with. My first question is about LT1's. Aren't they pretty much L98's with a better form of induction, reverse cooling, and optispark? Honestly, I don't really think you could tell much of a difference in the two if they shared the same form of induction. Also, why do some engines require self-aligning rocker arms, and some don't? I'm in the process of ordering heads and cam and want to make sure the valvetrain I have now will work. Also, what kind of power would a 355 with 10:1 compression running AFR 190's and an LT4 hotcam make? I want to be able to take down some lightly moded LS1's. My friend with an LS1 and cam runs right at 13flat, but with my combo I would hope for mid 12's with good traction. Anyways, any answers would be helpful.
Old Mar 30, 2003 | 03:27 PM
Aron213's Avatar
Car: 88 Iroc
Re: Engine Questions
If you look at it the way you are the 265's from the mid 50's are the same as the L98, just a different form of intake. But the Lt1's use different block and head cooling passages that will not directly bolt upto a 1st gen (55 to 92) engine the only parts that are the same are the crank and rods as comparred to a L98. All factory GM roller cam engines require self aligning rockers.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
