4 bolt roller cam 350
Old Mar 31, 2003 | 07:51 PM
TheViper's Avatar
Car: '84 Z28
Transmission: th2004r
i want to get a 4 bolt, factory roller cam 350 short block for my next engine. how common are the 4 bolt roller cam 350s in junk yards and such. how about 2 bolt, i would like a 4 bolt because it might see 400-500hp and maybe more in the future, hopefully a blower but by then i might have a 427 or 454 small block so a 2 bolt would do if i couldn't find a 4 bolt.
Old Mar 31, 2003 | 08:39 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
depends on how hard you look.... i found mine fairly easy... i got it out of a early 90s 350 truck... 4 bolt roller 1 piece rear main block...
Old Mar 31, 2003 | 11:07 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
not sure on the 4 bolts but 2 bolt rollers were used in f-bodies and corvettes from '87 and maybe in other fullsize cars, not sure. trucks went roller in the early 90s i think
Old Apr 1, 2003 | 07:17 AM
Deemax's Avatar
Car: '89 RS Convertible
Engine: 355
Yup. Same here. Paid 200 for the core.
Old Apr 1, 2003 | 09:31 AM
Vader's Avatar
Just remember that you will be somewhat restricted in the aftermarket, since you'll need a four-bolt cam and prob'ly four bolt rockers. Most of the SBC cams I've used only have three bolts. And forget about using a roller timing set. You'll want your timing drive to stay nice and flat as it moves around the sprockets, since too many rollers in one engine can cause a complete loss of friction and a runaway condition.
Old Apr 1, 2003 | 09:39 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Vader, play nice.
Old Apr 1, 2003 | 11:06 AM
Deemax's Avatar
Engine: 355
Not true. As long as you only torque down every other head bolt and pre-lube your fuel pump with vaseline you shouldn't have any problem at all
Old Apr 1, 2003 | 11:20 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
and also make sure you only put one valve cover back on
Old Apr 1, 2003 | 11:32 AM
Vader's Avatar
Oh, come on! We ALL know that we need to put ALL the covers back on ALL 16 valves. I know it's a lot of covers and bolts, but you can't leave 15 of the valves uncovered.
Old Apr 1, 2003 | 01:30 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
HA!!
Now, I have a '93 Z71 with a 350 and I was ASTOUNDED to find out when I pulled the intake to replace the leaking intake gaskets that my truck is NOT a roller 350. I was hoping to use it as a builder engine someday. Guess I'll have a non-roller builder, huh?
Ed
Old Apr 1, 2003 | 02:14 PM
Deemax's Avatar
Engine: 355
Originally posted by ebmiller88
HA!!
Ed
Damn...I didn't know those thieves had gotten all the way to GA too. A few months ago we had a big problem here in NY with guys stealing the rollers out of our 350s and dropping in their worn out hydraulics. I guess they got to you too ebmiller. Tough break man. Maybe you should call the GA state police, so they can start tracking these guys....
junkcltr
Aug 2, 2019 11:12 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
camaro71633
Sep 1, 2015 10:24 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
