Those running 383
Old Apr 1, 2003 | 02:18 PM
KMAN's Avatar
Those running 383
What is your bottom end. im starting my homework for later this summer and i have a good idea on heads and intake, AFR 190 or 195's and the lightnfelter super ram. just need a good strong bottom end. need it to take nitrous later down the road. any help would be great thanks
Old Apr 1, 2003 | 04:20 PM
e-man's Avatar
Car: 89 formula
Engine: 383
I used a Scat 9000 crank,Scat stroker rods,and Speed Pro pistons.Since you want to spray it I would use a Callies dragonslayer crank,Manley H-beam rods,and forged pistons SRP,JE or Ross.This set up should be safe for around 750 HP.
Old Apr 1, 2003 | 05:04 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
My 383 uses an 80 block, Cola forged steel crank, Eagle forged steel rods, and SRP forged pistons.
Old Apr 1, 2003 | 05:53 PM
KMAN's Avatar
92, do you run that on pumpgas? do you have any 1/4 times
Old Apr 1, 2003 | 06:14 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Yes, pump gas= 93 octane
No times yet. However, HITHERE did smoke my friend in his 98 Cobra with some work done to it!!
Old Apr 1, 2003 | 06:16 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
[HITHERE]Originally posted by 92 zzz28 [/HITHERE]
HITHERE
HITHERE did not type that and HITHERE tried to edit it out!! What the hell is it??!!
Old Apr 1, 2003 | 06:20 PM
rezinn's Avatar
St.op .insert..ing HITHERE eve.rywhere, d.ud.3.
Old Apr 1, 2003 | 07:43 PM
gtabadboy's Avatar
Read my sig for bottom end. HITHERE still need tons of tuning. The long block assembled was about 7,200 (including intake manifold and carb). It is all forged and nitrided.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Reddeath210
Oct 6, 2015 08:20 AM
86White_T/A305
Aug 17, 2015 12:16 AM
sreZ28
Aug 14, 2015 07:48 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
