fuel tank removal day pics
Old Apr 2, 2003 | 11:15 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
heres what you gotta do if dont have current access to garage and lift, i have one this both ways now and well i have to say that having car overhead on lift is alot more reccommended, it was a b*itch to manuever the tank out out of the body cavity like this just now:
http://photos.yahoo.com/bc/fastr68/l...isc.+I&.view=t
anyone know where i can find some fuel tank related hardware i am missing on the car: the two larger front-most vertical strap bolts that thread into the two clips clipped onto the body tub under the rear deck for these two bolts, i also need another one of those threaded clips and then i need the three screws that hold the driver side flat end of the panhard bar to the body tub they thread into body tub, and then i need all the tin heat shield screws i can get my hands on for up around the fuel tank
thanks
Old Apr 2, 2003 | 01:37 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
wow, im glad my fuel pump is mechanical, looks like a pain, anyway id just check a junkyard or gm dealership, or you could steal them off someone elses car in the middle of the night, heehee
Old Apr 2, 2003 | 01:40 PM
CrispyClutch's Avatar
Whats really a pisser is when you see posts like this and the next day the new fuel pump quits working for some reason...
Old Apr 2, 2003 | 01:49 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
lol yeah that would be funny, but whats even funnier is that it wasnt the fuel pump that was bad in the first place, all it was was the fuse in front fender burnt cuz wire harness across bellhousing wore through and shorted on tranny dipstick tube bracket mounted to a bellhousing bolt. previous owner cut hole in rear deck and cut all the lines up there so that ruined that sending unit, and they had already removed straps bolts and three panhard mounting bolts on driver side and some other things and lost them all and the one clip i need too.
no junkyards around here, id have to travel to springfield to possibly find what i need.
i may call dealer, i gotta do something, i wanna get this thing back together and back running again so i can sell or trade it off, theres a kid whos got a beater '83 K20 pickup i am interested in and he likes the car as soon as i fix all this on it,
thanks
Old Apr 2, 2003 | 05:12 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
oh and the force of the axle hanging down busted endlink bolt on driver side sway bar
Old Apr 3, 2003 | 03:30 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
ok, i really need one of these fuel tank strap bolt clips asap. not having luck locally at all,.
http://us.f1.yahoofs.com/users/193dd...JjKj.A7Q6QLvhK
[http://us.f1.yahoofs.com/users/193dd...JjKj.ATKidc3zE
thanks
Old Apr 3, 2003 | 10:33 PM
Hulk0202's Avatar
No way! You mean it's not a good idea to jack your car up at a 60* angle with a engine hoist ande nothing supporting the axle
? You have got to be kidding me.
Old Apr 4, 2003 | 01:00 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
the first autobody shop i went to gave me a clip ! the guy i walked up to to ask about it immediately knew what it was and knew the size and all, 10mm, he gave me it and told me to pocket it
the smaller one in this pic:
now i gotta reassemble car today ! hmm..
thanks to all here!
mustangman65_79
Apr 14, 2017 05:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
3rdgenparts
Aug 8, 2015 07:09 PM
