Underhood insulation removal?
Old Apr 3, 2003 | 03:29 PM
Svelte_SS's Avatar
Car: 1987 Monte Carlo SS
Engine: 5.7L TPI
Transmission: 4 spd auto
Hi, I'm trying to reduce as much weight as possible from my car and was wondering if there are any adverse side effects from removing the underhood insulation Will it peel my paint off the hood? Anyone know how much it weighs? Thanks...
Old Apr 3, 2003 | 04:36 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Doesn't weigh much, and i've never seen it cause a problem with peeling paint either.
This isn't really TPI specific so i'm moving to general tech...
Old Apr 3, 2003 | 06:13 PM
joshp14's Avatar
If you are that desperate for weight i would suggest removing wire looms, ash tray, and fine granules from your carpet . The hood insulation doesnt weigh anything compared to the performance times on your car. The only thing that i think that it really does is keeps heat under your hood for better warm up in the winter.
Old Apr 3, 2003 | 07:13 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
I remove it from any vehicle that I want to keep for a long time so I can see if there's rust getting started under the hood; the paint on my cars has never been affected by heat from doing this.
Old Apr 4, 2003 | 10:45 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
take it off. it does nothing but make you dirty when you rub on it.
Old Apr 4, 2003 | 10:59 AM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
Sorry guy's, but the peice you are all talking about is a fire blanket. It is designed to drop on the motor if it cought fire.
Old Apr 4, 2003 | 11:31 AM
Ed Maher's Avatar
Car: 04 GTO
Thats a theory that goes around as well, but even if that was the factory's purpose in putting it there, it still isn't going to drop down until all the plastic clips melt, which would be well after everything else worth salvaging under the hood was cooked anyway, and due to the shape of everything under the hood, and the insulations relative stiffness, it isn't going to do much of a job at smothering a fire anyway.
Old Apr 4, 2003 | 01:31 PM
Car: 91Z
Ha, you are very right about that, it does not really seem like it would work, but that's what they call it at the truck factory.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
Twin_Turbo
Mar 14, 2016 10:10 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
