Spacer and/or gasket?
Old Apr 2, 2003 | 11:50 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
I got an 1/2" Phenolic spacer for my Q-jet. Do I need a gasket on both sides of it, or does it act as the gasket?
...and the stock q-jet mounting gasket(1/4") on my lg4 stock intake was open (not 4 hole). I want to install a 1/2" phenolic spacer. Should I get an open one or 4 hole. I have read the info on the torque and hp benefits between the two, but if the stock gasket that was about 1/4" wood material was open, is there something that won't work correctly with a 4 hole design? The stock intake is divided except for a 1/4" deep, 1" dia, opening between the sides, plus there is a 1/8" deep indentation in the front, between the primaries that leads to the primaries.
thanks,
phil
__________________
thanks,
phil
sheachopper
Jul 31, 2019 11:27 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
