Timing problems...only achieving 9 deg of mech advance
Old Apr 4, 2003 | 04:17 PM
Troy 85Z's Avatar
Car: 85 Z
Engine: Edelbrock Injected 350
Axle/Gears: 3:42 LS1 Posi
I've got a non-computer Accel blueprint distributor that is only getting 9 degrees of mechanical advance. Currently I've got it set at 16 degrees base (600 RPM), though I can go up to 24 degrees no problem. The advance increases as it should to about 1100 RPM, when it reaches 9 deg mech. or 25 deg total. I ran it up to 4000 RPM and it stayed at 25 deg the entire time. Another problem occurred when I brought the idle back down. Any time I return to idle it takes about 3 seconds for the timing to return to base. It acts like the mechanism is sticking or bound up. For reference it is an Accel HEI Blueprint distributor (#59107). The book says it should have 24 degrees at 2800 RPM. And yes I had the vacuum advance disconnected.
Thanks,
Troy
Old Apr 4, 2003 | 05:02 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Advance weights hitting the rotor.
Old Apr 4, 2003 | 06:22 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Exactly.
Take off the rotor and look at it carefully, I'll bet you'll see where the weights rub. Probably one of the little reinforcement ribs. Grind a little material off.
Old Apr 4, 2003 | 07:06 PM
Troy 85Z's Avatar
Car: 85 Z
I took off the cap and rotor and there were no unusual wear marks. Nothing seemed bound up or interfering either. The instruction sheet says that different sleeves can be put on the advance stop pin, I assume to alter the max advance. Has anybody had experience with removing or reshaping these bushings?
Old Apr 4, 2003 | 07:24 PM
ronterry's Avatar
Car: '94 Corvette
If it's anything like MSD, you should be able to get different size stop bushings. (yes) These allow for tweaking the amount of mech adv.
I think mine are 20 or 22 can't remember. My total right now is 36, and my initial is -what- 14 or 16...
I can't even imagine they would put a 9° stop bushing from the factory!
What strength springs do you have on? They might be to strong to open up below a ridiculously high rpm.
You want to make sure you can get it all (34-38°) in by 3000 or so.
Ron
Old Apr 4, 2003 | 07:27 PM
ronterry's Avatar
Car: '94 Corvette
Also Troy, do you have any type of ignition box (like MSD 6A)?
Some timing lights do wackey things with capacitive discharge systems.
Ron
Old Apr 4, 2003 | 07:45 PM
Troy 85Z's Avatar
Car: 85 Z
No, I don't use an ignition box, at least not yet. Tomorrow I'm going to look at the stop pin and see if I can do any adjustments there. Supposedly there is an adjustable slot that controls max advance. If so that might be my problem. I'll know more tomorrow. Thanks for all of the advice so far.
Old Apr 5, 2003 | 12:51 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
mech adv problems
I have run into my fair share of mechanical advance issues. I have a mallory hei (with their "new mechanical advance mechanism") and it wasn't advancing more than 4 degrees, no matter how high it revved. I checked over everything, the weights moved freely, bushings were new, no unusual wear. Come to find out that the center plate (that advances the rotor when the weights push on it) was shaped different than a stock hei center plate. Went to u-wrench-it and pulled a stock one, cleaned it up, now advance works just fine... hope my little adventure can help!
Old Apr 5, 2003 | 01:11 PM
Troy 85Z's Avatar
Car: 85 Z
I took everything apart this morning and found that there was a tiny bit of wear at the tips of the weights so I gutted the underside of the rotor where they may have touched. This did absolutely nothing for the timing. The springs are the medium strength, full advance at 2800 RPM. I did notice that there were bushings in the slot to limit total advance but I couldn't even get it to touch the stop. It seems like the shape of the weights or center section could be off or something. I'm thinking that I'm going to try thidgen88's idea of replacing the mechanism. Does anybody know of a kit that has weights that are thinner at the tips, this might help reduce rubbing. Thanks guys
Amillionoh7
May 24, 2020 08:01 AM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
Thirim
Aug 9, 2015 06:19 PM
djmarch
Aug 9, 2015 05:27 PM
