Max lift on Stock heads
Old Apr 4, 2003 | 05:54 PM
zerotosixtyV8's Avatar
Car: Camaro
What is the max lift on stock L98 cast iron heads?
Old Apr 4, 2003 | 06:10 PM
e-man's Avatar
Car: 89 formula
Engine: 383
I use to run a compcam with .480 lift on stock 89 heads.I would NOT try running anything higher.
Old Apr 4, 2003 | 06:26 PM
Car: Camaro
I've got a set of .525" valve springs, I could use those to replace the stock springs
Old Apr 5, 2003 | 08:10 AM
e-man's Avatar
Car: 89 formula
Engine: 383
Its not just the springs the retainers could hit the valve seals too.What cam are you looking at and whats your set up?
Old Apr 5, 2003 | 11:19 AM
Car: Camaro
XR269HR or XR276HR, leaning towards the XR276 cause it's fitting the mods I've got and getting. SLP Headers, LS6 injectors, Stealth Ram, and Hooker Catback. Also a 3000 stall.
Old Apr 5, 2003 | 11:50 AM
ede's Avatar
ede
.46 or so is about the limit of pull out studs. .44 or so is the limit on factory springs, if they have any use or age on them it's time to replace them anyway.
Old Apr 5, 2003 | 01:20 PM
Vader's Avatar
Since you're already replacing the camshaft, you might as well maximize the setup by working the heads a little. You need to machine the guides to clear the retainers regardless of what elses you do, so the extra cost of enlarging the spring seats and cutting the guides O.D. for positive seals should be negligible - they're already set up to cut on center over the top of the guide anyway - and can use one cutter for the whole operation.
If you're really planning ahead, you can have them flip the head and machine for 2.02/1.60 valves, then run a boring head down in the valve bowls to open them enough to take advantage of the larger valves. The last time I did this it was only another $65 for the valve and bowl work. Of course, the new valves will set you back another $160 or so, but it's a one-time cost.
Oh - are you still using the TPI? Never mind.
theshackle
Mar 5, 2017 06:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
gta90
Sep 15, 2015 04:00 PM
NWAsonoma
Aug 18, 2015 05:45 PM
anesthes
Aug 8, 2015 09:37 PM
