Fuel Return Lines
Old Apr 8, 2003 | 01:12 PM
silverpace's Avatar
Car: 82 Z28 Indy Pace Car
Transmission: 4L60
Fuel Return Lines
I'm putting a 350 w/ carb into my 82 Z28. My question is, what do I do with the fuel return lines. I plan on using a Holley blue elec. fuel pump w/reg. There are 4 lines that come from the fuel sending unit. One supply line, one that goes to the small plastic vent by the tank and 2 others. Is there a safe way to bypass the return lines, should I just plug them up? Any help is appreciated.
Old Apr 8, 2003 | 01:34 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
they can be left open.. but its an evaporation point
I used the return line for a second delivery line but it did not help much.. just aireated the fuel. I will be plugging it probably.
Old Apr 8, 2003 | 01:54 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
One of those 2 is the return line; the other is the vent, goes to the canister.
If your pump has a return, hook it to the return; otherwise plug it.
You need some kind of a vent. Either use the canister; or take one of those little bronze fuel filters, and stick it on the end of the rubber hose that would go to the canister.
Grant2k
Jul 10, 2018 04:01 PM
AkDrifted
Aug 17, 2015 07:45 PM
wayshegoes
Aug 17, 2015 12:00 PM
armybyrd
Aug 10, 2015 09:23 PM
Kaweh
Aug 9, 2015 02:54 PM
