which cam for tpi 350?
Old Apr 8, 2003 | 02:11 PM
miller90Iroc's Avatar
I am building a 355 small block with rewoked 305 heads, i had 1.94 valves put in and am running headers, commpresion should be between 10:1 and 10.5:1, a stock tpi setup, but the plenum is ported, I plan on burning my own chip once it is running, and it is all going in front of a t5 temporarly, untill i can by a t56
what cam do you think would be the best, i have been looking at the comp cams extreme energy line, i think the xe-268, may be a little to much cam, so i am thiking i should probably go with xe-262, please help.
Jake_92RS
Jan 28, 2020 10:37 PM
camaro71633
Sep 1, 2015 10:24 AM
Out-Cast
Aug 17, 2015 10:57 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
