car ABC's
Old Apr 8, 2003 | 12:00 AM
SuperTrans Man's Avatar
Car: Camaro
Engine: 5.slow
Transmission: 5 speed manual
car ABC's
Well im doing a project for school its an ABC book and im doing it on car parts (dont ask please!!) i just wanted to get an idea i already named some of the more obveous ones but could u guys just name some car parts it woud be much appiricated and it would help me with my schooling oh and does anyone know of a car part taht starts with z i cant think of one but myabe im trying to hard
Old Apr 8, 2003 | 12:57 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Z bar.
Old Apr 8, 2003 | 01:47 AM
RJR99SS's Avatar
zerk fitting
Old Apr 8, 2003 | 11:21 AM
Vader's Avatar
If you're having a tough time with "Q", I can think of one that describes Mitsubishi drivers....
Or a quick-change rear carrier.
Old Apr 8, 2003 | 11:35 AM
427camaro's Avatar
Car: 05 Nissan Xterra
Engine: 4.0L DOHC
Transmission: 5 Speed Auto w/ OD
Air filter
Battery
Clutch
Distributor
Exhaust manifold
Fuel Pump
Gasoline???
Harmonic Balancer
Intake manifold
Jack???
Kickdown switch
Light bulbs
Mass air sensor
Nitrous
Oil cooler
Pushrods
Quater panels
Radiator
Shift kit
Thermostat
Universal Joint
Valves
Wheels
X
Y
Z bar
Old Apr 8, 2003 | 01:20 PM
Dan88IrocZ's Avatar
^ Guage (gasoline...hah)
Old Apr 8, 2003 | 01:54 PM
Car: Camaro
Engine: 5.slow
thanx guys now if i could just figgure out x and y i was thinkin for y Yet another broken ford but i dont think that falls under car part nessasarally but that helped big time and just wanted to say thanks for all the help
Old Apr 8, 2003 | 01:55 PM
MikeS's Avatar
X-wrench (tire iron), but that's cheating.
yoke?
Old Apr 8, 2003 | 01:59 PM
bcoop's Avatar
x-pipe for exhaust
Old Apr 8, 2003 | 02:22 PM
si_camaro's Avatar
Car: 85 Z28
Engine: LG4 modified
Y-pipe (for headers)
Old Apr 8, 2003 | 03:03 PM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Axle, Air Filter, A.I.R. Pump, Alternator, A/C [insert "compressor, tank" etc. here], A-arms, Anti-sway Bar, Anti-Lock Brake System
Bumper, Battery, Badges, Bearings, Body
Caliper, Coilovers, Clutch, Catyletic Convertor, Carburetor
Driveshaft, Distributor, Dimmer, Dashboard, Door
Engine, Emblems, Exhaust [insert "pipe, manifold" etc. here]
Fender, Frame, Fuel [insert "pump, tank, gauge" etc. here]
Gauges, Ground Effects, Governor
Headers, Heads, Heat Shield, Headliner, Headlights, H-pipe, HVAC Controls
Intake [insert "manifold", etc. here], I-pipe
Jumpers
Kickdown Switch, K-member
Lifters, Lights, Lower Control Arms, Locks
Muffler, MAF Sensor, MAP Sensor
Nitrous Bottle, Nose
Oxygen/O2 Sensor, Oil [Insert "Pump, Sump, Tank, Pan" etc. here]
Pistons, Piston [Insert "Rings, Heads" etc. here], Pushrods, Parking Lamps
Quarter Panels
Radiator, Radio, Roller Cam, Reverse Lights
Springs, Suspension, Shifter, Shift Kit, Shift ****, Spare Tire, Servo, Side Markers, Sub-frame Connectors, Supercharger, Spoiler
Tires, Thermostat, Temperature Gauge, TV-cable, Turbocharger, Throttle [Insert "Body, Position Sensor" etc. here]
Universal Joints, Upper Control Arms
Valves, VATS
Wheels, Water Pump, Wing
X-pipe
Y-pipe, Yoke
Z-bar, Zerk Fitting
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
