service engine soon
Old Apr 9, 2003 | 04:56 PM
IROC_Vert's Avatar
Car: Camaro IROC-Z Convertible & Camaro
Transmission: Auto & 6 SPEED
Axle/Gears: 2.73 & 3.42
service engine soon
My service engine soon light comes on every time I turn the key to the on position and will go out as soon as I turn the ignition... so far so good, but when I try to read the trouble codes by putting a wire from the 6 to 12 terminal on the ALDL port it just stays on and does not blink at all to give me the trouble code….
The car is running good except for a little power loss above 3500rpms (but that might be because of a problem with the cat) so I don't think the ECM or prom is messed up. What's the problem?
Alex
Old Apr 9, 2003 | 06:04 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Does the cooling fan turn on? I think you could be jumping the wrong terminals. The correct ones are the top two furthest to the right. You shouldnt be jumping one directly below the other, they should be side by side. If you are jumping the correct terminals, and the SES isnt flashing a code 12, the ECM cant communicate. This likely will not hinder any performance by itself, but any trouble codes that would will not be able to be retrieved. Id say recheck your connection.
Old Apr 10, 2003 | 11:54 AM
Vader's Avatar
Deutsche IROC,
Teh SES lamp turning on when the ignition is on without the engine running is normal.
As for retrieving the error codes, the ALDL is not labelled with numbers, but with letters. This is the pin designation:
To retrieve the error codes, the jumper needs to be installed between the 'A' and 'B' terminals. Turn on the igniton without starting the engine. Monitor the flashes on the SES lamp.
Old Apr 10, 2003 | 05:05 PM
IROC_Vert's Avatar
Thank you all, I got it working, its only trowing a code 12, which should mean that everything else is okay
Vintageracer
Jan 10, 2020 05:33 PM
backtothe80s
Sep 5, 2015 12:39 AM
Jae992
Aug 27, 2015 09:07 AM
kyleb24
Aug 15, 2015 08:24 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
