Opinions needed
Old Apr 10, 2003 | 04:27 PM
jeffsbluez's Avatar
Car: 91 z28
Opinions needed
I want to run my crank case gases into the exhaust. I already have the pass side going directly into the exhaust with a breather on the driver side. I want to run the driver side right to the exhaust to help pull a little more vacuum. My question is will not having a breather cause a problem at idle? There will not be enough vacuum created by the exhaust to open the check valves. Will this create too much pressure in the crank case at low engine speeds? Any and all opinions will be appreciated
Thank you-Jeff
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
