Will fixing A/C affect reliability?
Old Jul 20, 2000 | 06:53 PM
Fire Chick's Avatar
I've owned my current Thirdgen for almost 2 years, and the AC has never worked. The fan will blow hot air but it never gets cold. The previous owner told me that "the compressor was froze up." (not sure if this is true cause some other things she said weren't right either)
Anyway, I finally decided to have it diagnosed next week by my trusted mechanic of 15 years, and if it's not too expensive to fix I'm going to go ahead and fix it cause I'm taking a long trip shortly. (If it's too much $$ I'm not gonna bother because up here where I live you really don't need it very often.)
Anyway, since with these cars it seems like whenever you fix something that is broken, something ELSE goes wrong, my question is, what can I expect to have a problem with if I go ahead and fix the A/C? I don't want to get out in the middle of the desert and have the car crap out on me. The car has approx 140K and seems to run great, (knock on wood! )other than a little oil burning.
Fire Chick
Black 84 T/A, H.O. L69, 5 spd, 3.73's
Future mods: rebuilt engine with lots of chrome!
http://www.fbody.com/members/fbodyce...firechick.html
All-Knowing, not-easily-offended Warrior Princess of the Non-famous Cascade Crew
Old Jul 20, 2000 | 07:03 PM
JAMES POLEDNA's Avatar
As far as reliability is concerned there is no concern provided the work is performed competently. One thing, do not be surprised if the mech finds more than one prob with the system since cars do have a tendancy to deteriorate especially when they are never exercised. Although, mine sat for 6 years and it still works. check sig.....
bought a wrecked(head on,bad)'84 Z28 rebuilt it in'92 parked it in
'93 and ordered a '93 Z28. Got tired of the 4th gen in '99 and sold it and begin swapping in '85 TPI converted to speed density. engine is all stock except for comp cam. body has '86 IROC nose peice,ground fx and IROC wheels/goodyear 245/50's. IMO this car looks and feels more "racey" than my '93 did. and I love driving it. BTW fuel injection is great I'll never go back to carbs.
89RS355's Avatar
As long as everything else is in decent shape, I don't see a problem. But be prepared to pay out the *** . I am sure you will need new:
Reciever Drier
Evac+recharge
Possible compressor or just the clutch (that's the part that locks up most of the time)
Possible new lines, you wont know for sure until you fix everything elese, unless there is a gapping hole in one of them..
And then even after that, you may have other trouble that wont show up till a little later on. mainly pin-hole leaks that are next to impossible to diagnose until you get it up and running with dye in it. Just keep that in mind when he quotes you a price, if he is a good mechanic he will tell you that you might have possible undecteted problems later on. On the plus side, after all that there is not too many expensive things to go bad.
Jerry
Jerry
89 RS Lt Blue T-Tops T5
355 Crate, Compucam 2040
Pst Front Hotchkis Rear
Edle. TES 3" Flowmaster
Harwood hood, bla, bla, bla...
94 Z28, LT1 6M, Black
Most of the bolt-ons
Old Jul 20, 2000 | 08:17 PM
Fire Chick's Avatar
Well thanks guys, I am keeping my fingers crossed for something maybe as simple as a recharge, but I doubt I'll get that lucky! I do trust my guy and he knows I won't put out a lot of $$ to fix it. It's just not worth it up here. Plus the whole motor and everything is gonna get overhauled at some point...I prolly will fix it for sure then...
Any other comments?
Old Jul 20, 2000 | 10:28 PM
Duck's Avatar
Moderator/TGO Supporter
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
Here's an archive from my AC fix-it file. Note the price markups on compressors, etc.
How to Retrofit Your F-body Air Conditioning System to R-134a
By Chris Renner (RennerINA@aol.com)
Background
Third generation F-body cars are anywhere from 8 to 17 years old now, and that usually means your air conditioning system is either wasted or is going south. It could be a number of things: bad compressor, a blown o-ring, or worse, the dreaded slow leak that no repair shop can find. So, you probably do what I’ve done for years, just get it charged up in the spring and hope it cools until fall. Well, that didn’t work for me this year.
Well, if you haven’t looked, R-12 (DuPont’s name for R-12 is Freon) is more expensive than ever--I paid $35 a pound, and since it is no longer produced it will only get scarcer and more expensive. To boot, after the shop charged my system (for $130), it wouldn’t run, turns out the compressor failed, too (and leaked out all of my $130 of R-12)! If you have a bad part, its actually cheaper to go ahead and convert the system rather than pay $35/lb. for R-12 (R-134a is $7/lb.).
I’d been wanting to convert to R-134a (Dupont’s name for R-134a is Suva) refrigerant for years, due to the high cost and eventual unavailability of Freon. This was the perfect time, and it turned out that it was a lot easier than I had been led to believe.
If your system leaks all the R-12 out annually, even if all the components are working properly, it is financially worth your while to convert to R-134a, recharging will cost only $60 instead of $120. Maybe more importantly, all the stuff need to charge an R-134a system yourself is available to anyone (no license required as with R-12). If you have a broken component (most often the compressor), it is advantageous to go ahead and retrofit while you are opening up the system. If you’re a/c works great and you don’t have any leaks, don’t worry about it-don’t retrofit until it becomes worthwhile to you monetarily.
I got two estimates from a/c service shops (both nationally known chains), one for $500 and something for replacing the compressor, orifice tube, and accumulator (not including recharging with R-12), and another for $700 for replacing basically everything. With an R-12 recharge, I was looking at $650-800 to get cool again. After telling them I thought they were rip off artists, I decided to do the work myself. I searched the internet and “educated” myself about air conditioning systems.
If you are wary of working on you’re A/C system, read on. Even if you leave the charging to a shop, you can still do the repair work yourself with a substantial savings on both parts and labor. Working on an empty system is easier and simpler than you might think.
Two internet sites I found that that deal with conversions are: www.delanet.com/~pparish/cond.htm, and www.echocheck.com/maconair/pa00002.htm. These sites are run by accomplished a/c service shops and will give you a comprehensive overview of retrofits of R-12 systems to the new R-134a refrigerant that is readily available and cheap. I recommend you read through these sites before starting any conversion work.
The essence of the conversion is this: If you are currently running R-12, you have two options. First, you can simply evacuate the system, charge with R-134a and PAG oil, and run as is. The lubricant used with R-12 is mineral oil. Mineral oil will not mix with R-134a, and thus you must use PAG oil. The mineral oil does not need to be removed, as it will seek out quiet spots in the system to just sit there. This is actually the recommended OEM retrofit procedure from automobile manufacturers. The second option is to have the system flushed, removing all traces of mineral oil. In this case, you use ester oil (I don’t know why, that’s just what is recommended). If you do not flush the system and use ester oil, it will mix with the mineral oil and “park” in the system, not lubricating the compressor (which will lead to failure).
I have been told that all hoses must be replaced as well, but this is not always the case. As it turns out, R-134a has a smaller molecular structure, and can seep out through older hoses. If your hoses are in bad shape, you might think about replacement, otherwise its not recommended as necessary. If it leaks out, it will be slowly, and an R-134a recharge is so cheap it’s not a big deal.
Supplies
What you will need: Retrofit Kit (two 12oz. cans R-134a, one can 8oz. PAG oil/ 4oz. R-134a, adapter hose, new R-134a service port adapters, retrofit label, new schrader valves), a third 12 oz. can of R-134a (for a grand total of 40oz.), a large bore schrader valve and valve removal tool, Snap ring pliers (if replacing the compressor), safety goggles and maybe gloves, and a normal assortment of metric and standard wrenches/sockets.
I also recommend sitting down with a Chilton’s Manual and learning the parts to your A/C system, especially the high-pressure and low-pressure sides, and the locations of the high-side and low-side service ports.
R-134a Pressures Vs. R-12 Pressures: Use different amounts
One key to the use of R-134a is the amount to use. At a given temperature, R-134a will have a higher pressure than R-12. Therefore, you must use LESS R-134a in your system than you would R-12. The formula is this:
R-12 amount x 90% - 1/4 lb. = R-134a amount.
In the F-body system, 48 ounces of R-12 are used (3 pounds). Thus, applied to the formula:
48 x .9 - .25lb (.25lb is 4 oz.) = 39.2 ounces of R-134a.
Obviously, if you are doing this yourself, 39.2 is an unrealistic number. I put in 40 ounces, which was easy because of the retrofit kit and the typical 12 oz. cans.
The Retrofit Kit
I purchased a Johnsen’s retrofit kit from Pep Boys, but any good parts store should have a similar kit. The best part about Pep Boys was that all the a/c stuff is on the shelf, so you don’t have to have some hilljack parts guy try to help you. The kit contained a hose for charging the system, service port adapters and valve cores, a retrofit label, one can of PAG oil (8 oz. Oil, 4oz. R-134a), and two 12 ounce cans of R-134a. You will need an additional can of R-134a to make 40 ounces. Manifolds are available with high- and low-side pressure gauges, but I don’t think they are necessary. If you are charging a dry system, the 3 cans of R-134a and one can PAG/R-134a is exactly enough, so as long as you empty it all in, you know the pressure is correct.
Replacement of Parts
No special tools are needed to do the job, even if changing parts. A new accumulator (the canister looking thing, also called a receiver/dryer) is recommended when converting, so I put one in along with a new compressor. Also, a new orifice tube is recommended any time the compressor is changed. This tube is a filter that keeps debris from circulating in the system (if the orifice tube contains lots of debris, I strongly recommend having the system flushed after all repairs are completed). The accumulator needs to have XH-7 or XH-9 desiccant in it to be compatible with R-134a. Luckily, the majority of off-the-shelf parts are designed to go either way (back to R-12 or convert to R-134a), so this was not a problem. Actually, my stock accumulator had XH-7, so it would have worked. But considering the age of my ’88 IROC-Z, the desiccant was probably not removing moisture from the system very efficiently, so I replaced it. Replacement compressors also typically come dry, with no oil-making conversions easier.
Replacing parts is helpful to the conversion because it removes mineral oil from the system. It is important to stress that removing it is not necessary, but every bit you can get out helps. When a system looses charge, it also looses the oil, because the refrigerant carries the oil with it--there will, however, always be some liquid oil left over.
I’m not going to go into the specifics of actually changing out parts, that’s what the Chilton’s Manual is for (remember, always disconnect that negative battery cable first!). However, I’ll tell you that it was far simpler that I ever thought, and the whole process only took me about 4 hours, including breaks.
If you are going to do the work yourself, have the system evacuated completely if it is not already totally empty. There’s no sense venting 3 pounds of Freon into the atmosphere-its illegal, dangerous, and supposedly not good for the ozone layer. Once the system is zero pressure (actually atmospheric pressure), its easy to work on. Be sure to lubricate any new seals (it’s a good idea to grab a non-pressurized can of mineral oil to coat the new seals, because PAG oil is mildly corrosive to rubber). DO NOT get PAG oil on paint, its like brake fluid and will take paint off. (I did not learn this the hard way, luckily!).
When replacing the compressor, keep some things in mind. Many 3rd gen cars will have a pressure switch located on the back of the compressor which turns on the primary fan when head pressure reaches a certain point (see Willie’s “Total Fan Control” Tech Article). This switch is NOT supplied with a new compressor, and must be transferred to it. You will need snap ring pliers to get the thing out. Once the snap ring is out, simply pull it straight out (it might require some wiggling, but its not threaded in or anything).
Second, drain out the oil from the old compressor, and add approximately the same amount of PAG oil to the new compressor. This is important to prevent burning up the compressor. The PAG oil charge supplied in the retrofit kit actually contains sufficient oil for the whole system, but It is my opinion that its better not to run the compressor dry, even if for only a few moments. Only add at most a couple of ounces of PAG to the compressor, too much can be as bad as not enough! Once the compressor is installed and the lines are attached, use a socket to turn the clutch hub clockwise about 15 revolutions. This will properly lubricate the compressor. You don’t want too much oil in there, though, as this is bad too-just use good judgment.
Converting the Service Ports
Before charging the system, you must install the new service port adapters supplied with the kit. By law, every kind of refrigerant must have different kinds of ports to prevent mixing of different types. The new R-134a ports in the kit simply screw onto the R-12 ports. There is a low side port (with a blue cap) for the adapter located on the accumulator. This is the ONLY port you should charge the system with. The kit supplies two kinds of high side ports (with red caps) (high-pressure port is located on a line just in front of the orifice tube fitting), only one of which will fit our cars.
The instructions to the kit instruct you to remove the schrader valves from the two ports and install them in the new port adapters. The Low-side valve is just like a tire valve, and a typical core tool will work. The valve in the high side port is of larger diameter and requires the larger size valve core tool. If you use the normal sized tool, you will destroy the spring (like I did). I found the proper tool, along with a new large-bore valve core, at Advance Auto Parts.
The instructions recommend that the new service ports be installed with thread locking compound (they are not intended to be removed). BUT, I didn’t. I simply tightened down the ports until they were very snug.
Charging the system
I must recommend at this point that you leave the charging to a service shop. Although many people have successfully charged their systems at home, there are a couple of things you can have done at a shop that will extend the life of the A/C system and its components. First, if replacing the compressor, pay close attention to the old orifice tube. If there is a lot of debris in the screen, the system needs to be flushed to remove any additional contaminates, as they will destroy your new compressor. Expect to pay around $100 for a flush.
Second. Before charging a retrofitted system, it is preferable to have a shop pull a vacuum on the system to boil out any moisture and air remaining in the lines. The standard is 29in/hg for 30-45 minutes. With a moisture free system, the components will last longer and perform better.
Charging it yourself
If you are not willing, for whatever reason, to have a service shop charge the system, I’ve included those instructions anyway. I actually did it both ways…charged it myself and the compressor went out after two months, so the second time I left the charging to the pros.
I will assume that you are ready to start charging the system and are doing so according to the instructions supplied in the retrofit kit. Start with the PAG charge, screw it into the charge hose supplied with the kit. Next, attach the other end of the hose to the low-side service port (with the new adapter on it). Tighten the wing-nut on the can-side of the hose all the way down, then back it out all the way. You will hear the slight rushing sound of the contents moving into the system. Hold the can upside down and above the service port. To remove, close the wing nut on the can first, then disconnect the other end of the hose from the port. Then slowly open the wing-nut again to relieve any left-over pressure in the can.
I recommend starting the engine and running the compressor to draw the contents of each can completely into the system. You will have to remove the plug to the clutch cycling switch (located on the accumulator) and jump the connections to allow the compressor to run. Do not run it too long, though, as it will burn the compressor up when low on oil and refrigerant.
Final Recommendations
The last thing you will need to do is adjust the clutch cycling switch. Located on the accumulator, the switch serves two functions: 1) it cycles the compressor on and off to prevent freeze up during use, and 2) it prevents the compressor from running if the pressure is too low. The switch needs to be set at 21 to 22 psi, to compensate for pressure differences of R-134a. The adjustment screw is located in between the two terminals on the end of the switch. It is typically set at 24-25psi with r-12, so ¼ turn of the switch counterclockwise should be -4 psi (1/4 turn = 4 psi).
The whole job was fairly simple. Total cost, including new compressor, orifice tube, and accumulator was under $280. Actually, I had a service shop price those three parts at $260, $18.99, and $79.00 each. I got them at Autozone for $130 (+$10 core), $1.99 !!, and $43.00. Talk about mark-up!!! The retrofit kit was $40, and the extra can of R-134a was $7. Other miscellaneous parts were about $15. I also saved about $150 or so in labor.
This article was updated on September 7, 1999 by Chris Renner with technical input provided by Bernard Tripp (aka GMTech). Bernard can be e-mailed at bctripp@gateway.net
Duck_Hawaii
Mint87IROC-Z5.7
Old Jul 20, 2000 | 11:54 PM
Russ-So Cal's Avatar
Have your mechanic do a thorough check out on your cooling system. When you get the a/c working, you are going to be putting hot air into the radiator from the condenser. If your radiator/cooling system is getting marginal, you'll have overheating problems when you use the a/c.
Old Jul 22, 2000 | 04:03 PM
Fire Chick's Avatar
Yikes...do I really wanna mess with this?
Old Jul 23, 2000 | 01:38 AM
How good is your mechanic? Is he thorough?
You don't need to know how to do the work if your going to have someone else do it. It really isn't a problem to get a cooling system to work with a/c. The car was originally designed to work with a/c and keep cool. It is just that when you have the a/c repaired, make sure he checks out the cooling system at the same time.
Old Jul 23, 2000 | 12:02 PM
John'89L98's Avatar
Fire Chick, try this to see if your compressor is truly frozen, or if it simply needs a recharge:
- With the engine off, find the connector that plugs into the aluminum A/C canister (drier/evaporator?) under the hood, on the passenger side.
- Disconnect the plug and use a piece of wire to short the two terminals on the plug together.
- Start your car up, turn the A/C on, and see if the compressor clutch engages. DO NOT RUN THE COMPRESSOR THIS WAY FOR MORE THAN A FEW SECONDS!
If the clutch engages, you're simply low on refrigerant. If this is the case, you might want to get a leak check done on it to make sure you don't have any leaks. I would also convert to R-134 at this time. Really simple if you buy the conversion kit at just about any auto parts store.
If the clutch doesn't engage, or it whines, howls, or squeels, you may be in need of a new compressor. Don't forget to check your wiring, fuses, etc. to make sure they're not the culprit.
Good luck, and let us know how it goes. - John '89 L98
Old Jun 25, 2002 | 10:50 AM
stock sux's Avatar
i have read how to check if the compressor is bad. is that the only part of the system that can go bad that is electrical. i know there is a wire connected to the compressor and the drier. as long as both of those are connected i should be fine. since i took off all of my emisions i have had problems with shorting things out becuase they were grounded through the emisions equipment. thanks for any help.
strayli
Dec 31, 2022 12:44 PM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
92firebirdguy
Sep 1, 2016 07:53 AM
BLK87Z
Sep 18, 2015 11:29 PM
Mdenz3
Sep 17, 2015 08:36 AM
