Idles tweaky when I start up.
Old Jul 23, 2000 | 11:47 AM
Arawn's Avatar
Ok, whenever I start my TA, it idles pretty weird. Never goes above 1000rpms, but it'll get really low, like down to 300rpms. It's only died once while I let it warm up. It's REALLY bad if I have the A/C or the vents on. But it'll start to bog down, then usually bumps up to 1000rpms, then slowly drop back down. After I drive a block it idles down around 600, maybe a little less if the A/C is on (which also sounds like satans little brother is living under my hood when it's on..)
Ok, I posted this earlier but the topic sounded dumb and I don't think it was getting noticed. any clues what to check for here?
'86 WS6 Trans Am
Old Jul 23, 2000 | 12:11 PM
Jeff87IROCZ's Avatar
I too had a problem with idleing. It wasn't quiet like yours but if it helps. I replaced my throttle position sensor and no more problem. I hope it helps.
92camaroJoe
Jul 29, 2023 07:57 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
