Need some motor help
Old Apr 11, 2003 | 10:01 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
This is for my brother.
It's a '74 Chevelle 350 that's in his thirdgen.
There's several problems.
He just added a Summit cam 488/488 lift about 1 month ago. Stock springs ( I know I know, he should have changed them, but this wasn't my doing)
It's also has a Holley 600 VS carb.
I haven't had a chance to listen to it, but he says it idles real rough now. It will cut out and an occasional backfire thru the intake. At first I was thinking maybe a choke adjustment problem, but then he said they didn't change the springs, so I told him tomorrow pull the valve covers and check the springs.
Also, there is a lot of soot on the exhaust pipes and he also said there was gas in the pipes.
Can anyone shed some light?
I know a busted spring would cause a poorly running engine, but what about the other symptoms?
Thanks for any help.
Old Apr 11, 2003 | 11:09 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
he probably pulled out a rocker stud and has a valve that won't shut.
If he doesn't, he will. That's too much lift for a stock spring... especially one from an old smogger head. Hell, that's WAY too much cam for those heads, but that's another battle all together...
Old Apr 12, 2003 | 06:15 AM
ede's Avatar
ede
it's never ran right since the cam swap? did he/you degree the cam? if not you really don't know where it's at? did he install it straight up? check timing, valve adjustment, look for bent push rods, coil bind, pulled out stud, but i doubt that happened, vacuum leaks.
Old Apr 12, 2003 | 07:23 AM
Car: 99 Formula
Axle/Gears: 342
It ran fine till the other day. It was not degreed in though.
Old Apr 12, 2003 | 08:00 AM
ede's Avatar
ede
ok since it did run ok i'd look at broke valve spring, pulled out stud, bent push rods
Old Apr 12, 2003 | 09:21 AM
kevinc's Avatar
Car: 1982 Z28
So, uh, how does a pulled out rocker stud cause a valve to not close in your world?
The stud locates the rocker fulcrum...raising it would limit the amount of valve opening, not closing.
Old Apr 12, 2003 | 11:46 AM
Vader's Avatar
MAS,
Was anything done to the heads? 0.488" is just about beyond the interference point for those "lovely" little exhaust valve rotators and the tops of the valve guides on those mid-'70s heads. I'd be looking for valve train damage before running it again.
BTW - When you get the rocker covers off, check the head casting numbers.
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
madsv1000
Aug 20, 2015 06:45 AM
slade5612
Aug 11, 2015 07:19 PM
