Changing a knock sensor
Old Apr 12, 2003 | 08:59 PM
85rocker's Avatar
Can anyone tell me if I have to drain the coolant before I remove a knock sensor on an LB9 ?
Old Apr 12, 2003 | 10:21 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
yep. or you can just unscrew the old one and get the new one in as fast as you can so you only lose a little bit of coolant. make sure to use teflon tape on the new one
Old Apr 12, 2003 | 11:13 PM
Bugsy's Avatar
You won't lose hardly any radiotor fluid at all by just changing it as fast as you can but tie a towel around your arm so the fluid doesn't run down your armpit. Secondly, I don't think you should add teflon...it already comes with as much as it needs on it and you shouldn't change it. Torque it to 15lbs exactly...no more or your light will come on. Also, get one from the dealer because they had a recall on these on some of the camaros.
Bugsy
Old Apr 12, 2003 | 11:18 PM
Car: '87 Camaro LT
Engine: 355 L98
oh oops, i didnt know they came with teflon on them already. if you add more you could desensitize it
Chuck84TA
Jul 15, 2016 09:05 PM
db057
Sep 4, 2015 07:57 AM
bamaboy0323
Sep 3, 2015 06:07 AM
db057
Aug 22, 2015 08:17 PM
