Antifreeze leaks into oil
Old Jul 23, 2000 | 05:00 PM
jamesmc's Avatar
When I drained my oil antifreeze has leaked into was wondering where all the antifreeze had gone. Anyone know what the problemm could be?
Thanks in advance
Old Jul 23, 2000 | 05:02 PM
TransAm86's Avatar
A warped head... blown head gasket...
rebuilt time I'dd say
THAT'S RIGHT!
http://www.geocities.com/my1986transam
86' Pontiac Trans Am
305 LG4, 3.73 richmond rear
Old Jul 23, 2000 | 05:05 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Could be a cracked head, blown head gasket, blown intake gasket. I would run a compression check, and if all was OK, I would replace the intake gaskets. If that doesn't fix it, then I would have the heads checked for cracks.
"I used to have a handle on life, but then I used it as a plunger and broke it" -The Wave
ASE Master Tech + L1
Savannah, GA
'87 Trans Am-K&N,Cold air induction, SSM SFC, Flowmaster, 16" GTA rims.
'97 Bonneville SSE
About Me
Old Jul 23, 2000 | 05:32 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I'm with GMTech, check the intake gaskets first. They very often fail such that antifreeze gets into the crankcase. Look at the corners where its water passages are; if you can see any sign at all of water on the outside, chances are it's leaking to the inside too.
If the car works fine other than the leak, in particular if it has never overheated, then it's probably not a cracked or warped head or a bad head gasket or cracked casting. Intake gaskets are fairly easy to replace, start there.
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
bamaboy0323
Sep 12, 2015 07:14 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
