HELP! My Idle Is @1600 RPM, What Happened?
Today I hosed off my engine after I let it cool a bit. I got in my car drove about 60 miles and then at a stop light noticed my idle speed was 1200, so I though OK, WTF?? Then at the next light it was at 1600, WTF?? Finally, when I pulled into the Wallmart it was at 2200 and the Check Engine Light had come on, WTF WTF!!!! I shut off the car, got out and checked for any vacuum leaks. Found none. I let it cool off for about 30 minutes while I shopped then came back and it's been at a constant 1600 RPM all the way home. The Check Engine Light never came back one either.
WTF???? I have no vacuum leaks, now that I think about it, it was like that most of time, I just didn't notice because I was moving.
Please help me out??? Would water on something cause this???
Thanks.
1992 GTA (226 made), 1 of only 18 "Dk. Jade Gray Met. Primar" 92 GTA's, Window Sticker, 305 TPI, 700R4 4-Speed, T-Tops, Grey Leather, every option except rear disk brakes (Oh well, makes it 1 of a kind), and CD.
Current Mods: 80 Series Dual Outlet Flowmaster & TPIS Air Foil, THAT'S IT! 98% STOCK AND DAMN PROUD OF IT!!
Future Mods: Subframe Connectors, OE Replacement K&N.
"If it ain't broke, fix it til it is!"
[This message has been edited by 92GTA (edited July 22, 2000).]
Thanks.
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
My car does the exact same thing yours does!! Ive been figting this proablem for almost two years!! I have a Autoxray scanner and all my sensors are good. Just reciently I got a code 51 or 52 cant remember, but it turns out my computer is bad. So when I put the new computer in it should be fixed.
Convertible, L98, Edelbrock intake, runners & TES, SLP cam, Thin Head gaskets, March underdrive pulleys, Fastchips custom chip, Accel 300+ ignition, Relocated MAT sensor, TPIS airfoil & AFPR, K&N airfilters W/ chopped airboxs, Dynomax high flo cat, Flowmaster exhaust, MAC subframe connectors, B&M shift kit & XMSN cooler and NOS!!
Well, what does your car have to say about it? What codes come up under the check engine light? My guess would be that you got water in either your IAC or somehow in/under your distributor cap. But first, give us the codes, then we can go from there. - John '89 L98
Well, no water under the dist, and when I started it, it seemed fine idleing @1000. then when it warmed a bit, it went up to 1350 and now it just idles around 1200 very irratically like it cuts out every couple or seconds and then goes again. It never goes over 1300 or below 900, it just surges between. I'll go and get the erroe codes in a few when I can.
OK.....I pulled out my car and ran the error codes. I got 22, 33, and 45. then for **** & giggles, I disconnected my battery for about 1 minute to clear the codes. The I got back in my car, started it, and it ran perfect! I let it run for about 2 minutes reving it every now and then then I shut it off.
I ran for error codes again and got none and my car runs great now!
My question is, is running my car for just about 2-3 minutes enough for the computer to detect problems and store the codes or should I drive my car around to make sure?????
Thanks.
Thanks.
Well I just came back from driving my car for about 1 hour and it's still perfect. I guess I just got water in something. I checked for codes again and still got none so I guess the computer just neeeded to be cleared, cool.
Thanks.
Thanks.
Street Lethal
Apr 30, 2019 12:14 PM
