Engine break in - run it hard? or not?
Old Apr 13, 2003 | 03:45 PM
BTS88IROC's Avatar
I know this is a controversial subject but I just wanted to see what others said about this article I found, I came upon it while surfing through a Yamaha R6 website so it talkes mostly about bikes but would apply to cars also. I've heard both sides, the take it easy side and the run it hard side. Any other opinions. I'm not really sure what to think...
Here is a part of the article :
What's the Best Way to Break in
a New Engine ??
The Short Answer: Run it Hard !
Why ??
Nowadays, the piston ring seal is really what the break in process is all about. Contrary to popular belief, piston rings don't seal the combustion pressure by spring tension. Ring tension is necessary only to "scrape" the oil to prevent it from entering the combustion chamber.
If you think about it, the ring exerts maybe 5-10 lbs of spring tension against the cylinder wall ...
How can that small amount of spring tension seal against thousands of pounds of
combustion pressure on the way down ??
Of course it can't.
How Do Rings Seal Against Tremendous Combustion Pressure ??
From the actual gas pressure itself !! It passes over the top of the ring, and gets behind it to force it outward against the cylinder wall. The problem is that new rings are far from perfect and they must be worn in quite a bit in order to completely seal all the way around the bore. If the gas pressure is strong enough during the engine's first miles of operation (open that throttle !!!), then the entire ring will wear into
the cylinder surface, to seal the combustion pressure as well as possible.
The Problem With "Easy Break In" ...
The honed crosshatch pattern in the cylinder bore acts like a file to allow the rings to wear. The rings quickly wear down the "peaks" of this roughness, regardless of how hard the engine is run.
There's a very small window of opportunity to get the rings to seal really well ... the first 20 miles !!
If the rings aren't forced against the walls soon enough, they'll use up the roughness before they fully seat. Once that happens there is no solution but to re hone the cylinders, install new rings and start over again.
Fortunately, most new sportbike owners can't resist the urge to "open it up" once or twice,
which is why more engines don't have this problem !!
An additional factor that you may not have realized, is that the person at the dealership who set up your bike probably blasted your brand new bike pretty hard on the "test run". So, without realizing it, that adrenaline crazed set - up mechanic actually did you a huge favor !!
Link if anyone is interested - http://www.mototuneusa.com/break_in_secrets.htm
Old Apr 13, 2003 | 07:10 PM
ede's Avatar
ede
when you break in a new engine there are several things you need to break in , seat the rings and break in the cam and lifters. use 30w dino juice. have a light hooked up and ready to go, when it fires set timing and idle. run it between 1500 and 4000 rpm for 30 minutes, and i like sevearl heat/cooling cycles. change the oil to 30w again, run it under load from idle to 4000-4500rpm and change the oil again at 500 with 30w. after that i go to my regular oil chamge intervals and synthetic. i don't believe there's much in common between a air cooled engine on a motorcycle and the engine in a car.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Poncho92
Group Purchases
Aug 25, 2015 02:17 PM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Poncho92
Aug 7, 2015 08:15 PM
