A/C Problem
Old Apr 13, 2003 | 05:42 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
A/C Problem
My a/c compressor clutch doesnt seem to be engaging:
that triangulare plate should spin when the ac is turned on right? mine doesnt move even w/ ac on. i checked both sets of wire connections to the compressor:
neither had any power on them with car running and ac turned on. whats the next step, check the system for pressure? someone told me that if its out of gas theres a low pressure shutoff switch that wont turn the compressor on.
Old Apr 13, 2003 | 07:23 PM
84s/e's Avatar
Car: 1984 Firebird S/E
Engine: 5.0 lg4
You need to charge your system. Your compressor won't come on if there isn't any freon in it.
Old Apr 13, 2003 | 07:47 PM
TekViper's Avatar
Engine: 3.1L v6
how much does a recharge run?
Old Apr 13, 2003 | 08:57 PM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
depends on what type of freon u need, r-12 will run u about $33 per can, each can is 12oz and i think u need 3, buy 3 and if u dont use it keep it. r-12 is hard to come by and getting harder, if it leaked out before that means it will again and u will need it again. Though on newer cars they run r-134a freon, some older cars have be updated, most have not, if yours has that will run u about $15 or less per 12oz can, and again u will need 3 cans
hope it helps
Old Apr 13, 2003 | 09:22 PM
TekViper's Avatar
Engine: 3.1L v6
is there anyway to tell what type of refridgerent i have in there now? its a 1990.
Old Apr 13, 2003 | 09:42 PM
Transmission: autos
i know the valve on the little silver bottle (is it called a consedser) anyway it will have 2 fitings on it one smaller one and a bigger one screwed onto the smaller one, i doubt it has been changed over though
my86bird
Oct 23, 2015 12:20 PM
greenyone
Sep 2, 2015 03:39 PM
greenyone
Aug 29, 2015 11:08 AM
BikeFarm
Aug 11, 2015 11:35 PM
