What happened to my pushrod?
Old Apr 13, 2003 | 09:18 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I have attached a pic.
Old Apr 13, 2003 | 09:19 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Here is another.
Old Apr 13, 2003 | 09:25 PM
daverr's Avatar
is hard to see
its hard to see from that picture.so im guessing that the little ball on the end went into the tube correct??so here are the possible causes
1. incorrect pushrod for cam application
2.incorrect valve adjustment(too tight)
3 coil bind
4 improper valve geometry
dave
Old Apr 13, 2003 | 09:26 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I know these aren't the best pics but has anyone ever seen this happen? It looks like the ball on the end of the pushrod is smashed down into the rod itself. The other end is normal and has the ball looking thing on it. Is this a defect from the factory? If it is then I've used it like this for over a year and a half. I put some new ones in the other day and the motor runs so much smoother than it ever has. I know that I was losing some lift over it. The pushrods are hardened chromoly from Crane.
Old Apr 13, 2003 | 09:31 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Re: is hard to see
3 coil bind
dave
They are the stock length and I've never had them too tight that I know of. The springs were setup for the cam and came with the cam kit so I don't think that is binding. Now the valve geometry could be the problem. I bought a pushrod length checker yesterday so I will check that. My main question is did it come from Crane this way? I probably didn't look at both ends of all the rods when I put the engine together. I will from now on.
InfernalVortex
Apr 20, 2021 11:31 AM
RS Reaper
Oct 17, 2018 07:52 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
racereese
Oct 3, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
