My car is going insane
Old Jul 23, 2000 | 01:14 AM
Mo's Avatar
Mo
The other day my car overheated when the radiator drain plug broke and now after it warms up it dies when put in gear. It drives fine once your moving but will die if I come to a stop. My radiator was also leaking for like two days afterwards, but today it stopped leaking. But wait, there's more...if you call within the next 30 minutes we'll also throw in a passenger side fan that hasn't worked in like 3 months, but out of the blue decided to turn on today when the car was at like 130*. Only the pass. fan, not the driver's side fan. Then after shutting the car off and restarting it, i let it heat up to like 225* or whatever, when the fans come on, and like usual, only the drivers side fan came on. Any ideas? I think i'm gonna check it in to a loony bin on monday.
90 IROC 5.7l (L98)
ram air, K&N's, air foil,Flows
Old Jul 23, 2000 | 10:56 AM
Matt84TA's Avatar
With the fans? Stuff that doesn't work and then does all of a sudden is usually ELECTRICAL
I have a multitude of those in the firebird I need to find and work out.
When your car dies, does it lean out ? Does spark go away? What?
Old Jul 23, 2000 | 06:08 PM
Mo's Avatar
Mo
the rpms drop and it stalls
Old Jul 23, 2000 | 06:14 PM
TransAm86's Avatar
First change your thermostat(for the fan thing, maybe).... Check the wires, change the old rad hoses and please tell me that your collant levels are ok.. Other than the rad, is the water pump ok?
THAT'S RIGHT!
http://www.geocities.com/my1986transam
86' Pontiac Trans Am
305 LG4, 3.73 richmond rear
Old Jul 23, 2000 | 07:17 PM
Mo's Avatar
Mo
Coolant levels are fine, water pump is not weeping, thermo is relatively new and opens when its supposed to
90 IROC 5.7l (L98)
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
