throttle valve cable?
Car: 1989 pontiac firebird formula
Engine: Currently building a 355
if the throttle valve cable isnt adjusted right will it make my car sluggish on take off? in park motor revs greatbut go to take off and its a little sluggish get up to about 2 grand and it takes off like a demon getting splashed with holy water. l03 350 tpi cam carb swap (no tbi anymore) 10:1 comp shaved 58 cc heads 1.94/1.6 valves. thanx thomas
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
It only affects when and how hard the transmission shifts.
If it's out of adjustment one way and you're light on the gas it will shift super early and softly and make the car feel slower.
The other way (pulled out more) will cause later, harder shifts.
9192camaro
16
Feb 3, 2019 12:21 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
