Engine Removal
Old Jul 23, 2000 | 07:28 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Engine Removal
I have one quick question. If I remove my heads before I remove the block how much easier would it make the removal and install process.
Brian
Old Jul 23, 2000 | 07:51 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
Well really the only difference is that you removed it. Nothing else. It actually it will be kinda harder. Since you will have to put the heads into the car when the motor is already in. Which is harder.
Chris
91 RS 305 TBI
Team Neo Blood
Old Jul 23, 2000 | 08:04 PM
I will not make the bell housing bolts easier to get to and move the motor around? I am just looking for the easy way for one person to do the Job.
Brian
Old Jul 23, 2000 | 08:29 PM
REVLIMIT's Avatar
Engine: Built L98
Wait you probably don't have a lift and an engine houst do you? If not then It probably woudl be eaiser to take off the head.
Chris
91 RS 305 TBI
Team Neo Blood
Old Jul 23, 2000 | 10:35 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Im curious if he'll be able to get to the back head bolts with the exhaust manifold on, assuming it unbolts it at the donut.. If you
unbolt it from the head, don't break any bolts..
-- Joe
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
perZ
Aug 15, 2015 01:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
3rdgenparts
Aug 8, 2015 07:09 PM
