throttle position sensor??
Old Jul 23, 2000 | 11:36 AM
hookin88formula's Avatar
i have a friend that bumped his throttle position sensor up to about 6 or 7 ohms. does anybody out there know how to do this he didnt do it to his car someone else did and he cant remember where it is or how they did it if anyone could help that would be great. he said it helped out the throttle reponse big time.
thank u
Old Jul 23, 2000 | 11:57 AM
Vader's Avatar
88,
I'm not sure how your friend is checking and setting her/his TPS, but most of us set our TPS position by voltage instead of resistance. The ECM uses a voltage reference to determine throttle position, so the resistance is insignificant as long as the reference voltage (5VDC logic level) is correct. Stick to the key-on/engine-off voltage method and you'll have much better results.
Later,
Vader
"Some Body...Someone"
Old Jul 24, 2000 | 01:37 AM
VADER I DONT KNOW HOW HE ADJUSTED THE TPS. ANYWAYS I DO KNOW THAT HE USED AN OHM METER. BUT I NEED TO KNOW WHERE THE TPS IS AND HOW U ADJUST IT DOES IT REALLY MAKE THE THROTTLE SNAPPY??
1988 firebird formula350tpi msd 6al box blaster 3 coil accel 8.8 wires flowmaster cat back pro shift light a pillar gauge pod and water temp and air/fuel ratio gauges b&m mega console shifter
Old Jul 24, 2000 | 02:16 AM
Kevin Irving's Avatar
Car: 1985 Trans Am
Here is the article that will explain it in detail for you... DO NOT use an ohm meter!! Do what Vader or the article says and you will be fine.
https://www.thirdgen.org/tech/tpimod2.html
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, TB Coolant Bypass, Ported Plenum, Modified MAF, Cyclone Fuel Pump, JET Airfoil
Veiw my car at: http://www.geocities.com/transam85tpi/TransAm.html
GTAman
Jul 3, 2024 07:29 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
