how do you remove this (IAC?)
Car: 89 camaro w/t-tops
Engine: lo3
I removed my single snorkal for a open element.In the process I had to disconnect what I believe is the IAC.I cant figure out how to get it out of the old base!It doesnt look scewed in or pressed in and Im afraid to pull too hard since I dont want to break it.I'd like to get it off so I can reattach it to its harness because Im now getting a code 23.
Engine: lo3
ok i just looked again.It wasnt screwed on or hex shaped.There's a saying:if at first you dont succeed....cheat!
I took a pair of needlenose to it and pryed it off!I got it back on its harness and up agaist the firewall...hopefully my code 23 is gone.
