Flexplate install question.
Old Jul 22, 2000 | 12:31 PM
Alan84TA's Avatar
Its been months since I took my engine out and I can't remeber which way the flexplate goes on... It has buldges that the screws for the torque converter go through. Does the converter mount to the high side of the buldges? That is the way I have it and it looks right but just want to make sure before I get it back in.....
Old Jul 22, 2000 | 01:39 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The bulges face the torque converter, and you should also notice a ridge around the center hole which also faces the converter. It's actually pretty hard to put it on backwards and still manage to put the bolts in.
Old Jul 24, 2000 | 10:20 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
What a sore subject with me... I just R&R'ed mine - for nothing. Anyways, there's a chunk of metal one one side - don't know what the hell it's called, nor do I care, but that faces the engine anyways. Also, if you look real good, it SHOULD also be stamped as engine side, too...
84z96L31vortec
Aug 20, 2017 12:16 AM
ron reece
Southern California Area
Oct 7, 2015 01:11 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
gwade12
Aug 8, 2015 08:17 AM
Leggman1
Aug 6, 2015 04:15 AM
