2.8l to 5.0l/5.7l
Old Jul 23, 2000 | 09:43 PM
RiceEater's Avatar
2.8l to 5.0l/5.7l
I have the 2.8mpfi engine in my 86 firebird and i want to put a 305 or 350 in it. I have found a 305TPI and I just need to know if i would have to mess with the injectors and fuel lines to make the conversions?? Or could i just bolt it in and go?
Old Jul 23, 2000 | 09:48 PM
Blue502's Avatar
They are different. You will need the parts from the V8 car. Also computer, radiator, front springs...
Old Jul 23, 2000 | 09:57 PM
Powerhawk119's Avatar
I 've thought about the same thing! I have a 91 3.1 and MAYBE someday convert it to a V8( I already have a 350 4 bolt).
The Injection is a tricky thing. I know that you will need the fuel hardware thats on the engine(injectors,fuel rails, plenium, etc,)
A wiring harness and computer(V8 of course) along with all the plumbing(exhaust manifolds,hoses,etc)
I'm not sure but you may need a bigger radiator for more cooling. Also, your front springs will need to be changed to handle the added small block weight!
If possibly, hunt up a wrecked car and get the entire thing so that you have everything that you need. I CAN be a pain in the @$$( which is why I haven't started yet).
91 Firebird v6(not much longer)
83 Toyota Celica GT(not your typical rice car! RWD and no"crappy" decals!
"Too fast to live, too fast to DIE!"
Old Jul 24, 2000 | 10:40 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I agree with PowerHawk... find a clapped out V8 f-body (the newer the better for the intake area), and rebuild the motor while you drive the 6 around. Then take a week off of work, and a week outta your social life and switch everything over. While you're at it, clean up the Firebird's engine bay too...
The only bonus you get is if you buy a v8 with TPI injection, the v6 MPFI motor uses the same in-tank fuel pump as the v8 TPI. (V8 TBI uses a lower pressure pump.) At least you don't have to drop the tank down!
Oh duh, didn't notice you had found a TPI motor already. In that case, you won't have to rebuild the v8 donor car's motor..
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.v6fbody.com mailbags
bplessy
Sep 30, 2015 12:14 PM
88rscamar0
Sep 23, 2015 09:08 PM
64goatman
Sep 9, 2015 01:09 PM
Chevy86 IROC-Z
Sep 7, 2015 01:13 AM
