how much hp will my motor make
Subscribe
Apr 16, 2003 | 12:57 PM
hi
how much hp do you think my motor will make
It is a 84 305H.O
with 1 5/8 heddman headers,
weland action plus intake manifold,
700cfm 4 bl carb.
and a mild street camshaft
287 287 214 214 . 444 .444 107 117
so how much hp will my motor make
THANKS
Reply 0
Apr 16, 2003 | 01:46 PM
Is 117 the LSA??? WOW!!!
I thought my cam with 112 was a lot. I hope that's a typo on your part.
Using 117..... DD2000 says 225-250 HP and right around 300 ft-lbs. of TQ. But there's too many other variables involved.
What exhaust are you running after the headers? Are you using stock heads?
Reply 0
Apr 16, 2003 | 05:12 PM
i think he means
107 intake centerline,
117 exhuast centerline
which would work out to a lsa of 112 with 63 deg of overlap
using 287 and 287
Reply 0
Apr 16, 2003 | 05:47 PM
is it is lobe center line
int. 107 ex. 117
i got the numbers on a web site
Reply 0
Apr 16, 2003 | 11:44 PM
Quote:
Originally posted by rustybluebird
i think he means
using 287 and 287
Where's my sign???
Well let me redo the numbers then.
Here's a pick of the two.. one with High Performance exhaust manifolds, and one with "headers and mufflers".... I'd lean more toward the HP manifold numbers since DD2000 is known to be a little optimistic on torque numbers.
Reply 0
Apr 16, 2003 | 11:52 PM
I think on most applications DD2000 over estimates. But those numbers look fairly reasonable at the flywheel. I would have guessed around 230- 240 at the flywheel, but heck thats just my opinion, and opinions are like aholes, everyone has one. But I think thats close.
Reply 0
Apr 17, 2003 | 07:04 AM
thanks
the motor got headers like i said and 3 inch exhaust with no cat
Reply 0
Subscribe
