Oil leak at base of dipstick
Old Apr 17, 2003 | 07:00 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
When I removed my headers the dipstick tube pulled out from the side of the oil pan. After reinstalling everything I have an oil leak from that same spot. It looks like it was removed before because there was a bunch of black RTV around it. Is that the best way to seal that and is it suppose to pull out that easily?
It looks like they just put the tube in there and smothered a crap load of RTV around it.
Old Apr 18, 2003 | 07:21 AM
Vader's Avatar
The dipstick tube should be a fairly snug push fit. You may have to swage the end slightly larger so it has a better interference fit. Sealant is optional.
Old Apr 18, 2003 | 07:14 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Is it common for oil to leak from there? Could it be from excessive crankcase pressure?
Old Apr 19, 2003 | 02:35 PM
Hung Start67's Avatar
Yes danny very commom to leak there..RTV if you need it should do the trick.
maroe624
Apr 16, 2017 08:29 AM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Navy8125
Aug 21, 2015 09:32 AM
drathaar907
Aug 6, 2015 04:20 PM
