drivability problems with auto chip in 5spd car
Old Apr 17, 2003 | 09:13 PM
87 B4Z's Avatar
i just swaped out a 700R4 for a T5 and my car sometimes dies while slowing down. does this sound like problem with the chip still thinking it has a auto tranny in it?
Old Apr 18, 2003 | 12:31 AM
bes217's Avatar
You do know that when you slow down in a manual you have to shift it into a lower gear or put in the clutch right?
Old Apr 18, 2003 | 10:15 AM
dd85T/A's Avatar
Car: 85 T/A
Did you connect the speedometer? When I swapped trannies I left the spdo not connected for a while. If the ecm does not get a signal from the spdo it will stall. You will also get a code for the vss. After I fixed the spdo(cable to electric)all was fine. The auto chip worked ok but the idle would hunt. I now have a correct chip and all is well.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
mustangman65_79
Sep 1, 2015 03:51 PM
NBrehm
Aug 25, 2015 11:49 PM
Exxon Limited
Aug 9, 2015 08:13 PM
mustangman65_79
Aug 8, 2015 12:07 PM
