Exhaust manifolds GLOWING CHERRY RED???
Old Apr 17, 2003 | 10:47 PM
Metallica383's Avatar
I have a stock 91 camaro 305 TBI. I noticed it while trying to discover what the problem is causing the car to lack power. I happened to looked down and the manifolds and they were glowing red hot. The car was not running no more than 5 minutes! What could cause this?
Old Apr 17, 2003 | 10:59 PM
2laneblacktop's Avatar
Probably running way lean.....try richening the mixture up. That may help both problems as well as save the engine.
Old Apr 17, 2003 | 11:03 PM
xaivior's Avatar
Car: Camaro
Engine: 355
Transmission: th-350
Axle/Gears: 3.73 welded
ditto to that
Old Apr 18, 2003 | 09:54 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Check your timing. Make sure its not waaay advanced
Old Apr 18, 2003 | 11:00 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Have you done any work to it lately? Besides what was mentioned, check your cat and see if it's glowing too, may be clogged.
Old Apr 18, 2003 | 11:58 AM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
if you still have the CAT on, then most likely it's clogged.
Old Apr 18, 2003 | 11:14 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
I agree, get out the timing light and make sure it's not too advanced... your engine could be going into detonation. Is your car starting hard too? That's another dead giveaway for too much timing. If the car just started doing this all on its own, make sure the distributor hold down bolt didn't work its way loose over time. If that's OK, then chances are your cat is clogged. Just my 2 cents.
AussiePr0nCar
Mar 6, 2020 04:04 PM
Reddeath210
Oct 6, 2015 08:20 AM
transaero
Aug 31, 2015 01:14 AM
Nj1987
Aug 19, 2015 08:26 PM
timonator
Aug 11, 2015 09:56 PM
