Installed jet stage 2 chip, 15 degs base?
Old 07-24-2000, 09:51 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
It advances the timing this much? The base was 8 before, So I put in the stock chip and reset the base to 6. I have not checked it again since I put the jet chip back in but my ? is itsuppose to advance it that much?
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Moroso Blue max wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Vintageracer
01-10-2020 05:33 PM
demontransam89
Wheels and Tires
12-28-2015 06:58 AM
toronto formula
11-10-2015 06:17 AM
fasteddi
09-02-2015 10:29 AM
drathaar907
08-06-2015 04:20 PM
Quick Reply: Installed jet stage 2 chip, 15 degs base?
