Opinion: What should my next mods be?
Old Apr 19, 2003 | 11:52 AM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
Here's your chance to tell me what you think. What should be my next mods? I don't know when I'll
buy them because I can't find a good money tree anywhere. Here are the specs:
1986 Trans Am
Engine
Professionally built Chevy 350 with 8,000kms
Balanced with ~ 9:1 compression
Hypereutectic flat top pistons
214/224 cam with .443/.465 lift and 112 LSA
Steel Crank
Heads
Casting #3986316 (1971-72)
1.94/1.6 valves, milled to 74cc,
Screw in studs, heavy duty double springs, retainers, etc.
Induction
Pro built Q-Jet (Originally from 7x? Z28)
LG4 intake
14x2" K&N open air cleaner
Transmission
Rebuilt 700R4 with about 50,000 kms
Trans-go Stage 2 shift kit, upshift valve
Stock converter
Rear End
Stock 3.23, open
Heddman shorty headers
Custom 3" Y-pipe
3" Flo-Pro I-pipe and muffler
Ignition
Stock GM HEI
Crane Distributor recurve
NGK V-power plugs
Jacobs 8.5mm wires
Timing: 10/32/48
Modine 4 row radiator (OEM for 70s big block Camaros)
Stock single fan
Suspension
Stock w/ Air Lift air bags
Other
Carter Electric Fuel Pump
Tires: 235/60/15 Front, 255/60/15 Rear
Performance
Best E.T. to date: 15.09 @ 93 mph, 2.50 60' (with passenger and stereo)
Best E.T. Corrected: 14.80 @ 95
Best 60': 2.31
Old Apr 19, 2003 | 12:36 PM
AFatHippo's Avatar
Car: '88 Camaro
Engine: 355
positrac and possibly a higher numerical gear ratio. a 3" y-pipe would make more sense since you have a 3" intermediate pipe.
Old Apr 19, 2003 | 12:49 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
I am a retard....The y-pipe is a 3 incher.
What kind of numbers are you getting with those vortec heads?
Old Apr 19, 2003 | 01:43 PM
AFatHippo's Avatar
Car: '88 Camaro
Engine: 355
havent had it dynotested yet. i hear they are supposed to be the best bang for the buck though.
Old Apr 19, 2003 | 01:50 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
I am guessing that I am making about 240-250 hp.
Ever had your car to the track?
Old Apr 20, 2003 | 10:04 AM
AFatHippo's Avatar
Car: '88 Camaro
Engine: 355
no, im waiting until i finish the break-in miles on the car. has 300 some so far. im also waiting until i finish the work on my rear end. after those are done im planning on taking it to the track.
Old Apr 20, 2003 | 11:37 AM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
What are you doing for a rear end?
Old Apr 20, 2003 | 01:44 PM
AFatHippo's Avatar
Car: '88 Camaro
Engine: 355
keeping the 10 bolt and using a positrac and 3.73s on it. im sure itll hold up since i only have street tires on and wont be launching hard at all. found a prospect on ebay, so im hoping thatll come through for me
Old Apr 20, 2003 | 07:04 PM
flyway190's Avatar
Is your intake manifold stock? If so get a better one. That alone made a 0.8 second and 2 mph difference on my car.
Old Apr 21, 2003 | 04:41 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Yeah its the stock LG4 intake...I would have never imagined 8/10ths though.
starliner
Feb 9, 2016 08:18 PM
Quzyle
Oct 15, 2015 03:35 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
