A.I.R Removal
Old Jul 25, 2000 | 10:28 AM
kidpunkr's Avatar
A.I.R Removal
ive got a 87 t/a w/5.7 tpi and its got that annoying air system on it ive already disabled,is there any reason, that i cant remove that system b/c we dont have emissions testing here???
Old Jul 25, 2000 | 11:03 AM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
If you don't have emmisions then pop that bitch out of there. It's just taking up space. And sucking some hp away from your car.
Chris
91 RS 305 TBI
Team Neo Blood
Old Jul 25, 2000 | 11:35 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Yes for sure, take it off. Just tape up the two connectors that go to the boxy looking stuff (air switch box). Not only do you remove the AIR pump, but also the mounting bracket, and the switch box along with some lines.
I removed all of this stuff from my '87 IROCZ.
'87 L98 TPI IROCZ, TF heads, 3.70 gears, LT1 cam?, 2400 Art Carr TC, SLP 1 3/4" headers, SLP cat-back, no cat, no AC, no MAF screens, Accel manifold base & SuperRam, Edelbrock double roller timing chain, MSD ext coil & distributor, trans cooler, 52mm TB, TB airfoil, TB coolant bypass, AFPR(48psi), K&N filters, Hotchkis lowering springs, Car-Pro custom chip, Lay Ind. ram air kit, 265/45R16 Kumho V700 tires, and still as slow as hell 13.82sec ET @ 106.3 mph. To be installed soon: TPIS ZZ9 cam, 2400 stall converter.
'90 Eagle Talon AWD, no rust thru 9 winters
'99 Camaro SS, red, 6-spd, T-tops, Mcleod clutch, Pro 5.0 shifter, MAF processor, Direct Flow lid, K&N filter.
313.7Hp & 320.6ft-lbf
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
