Do 3rd Gens use a unique starter Bolt Pattern?
Old Apr 22, 2003 | 06:07 PM
maksik7's Avatar
Hey guys, I had to replace a bad starter on my 86 TA LB9. I also had a spare starter lying around (from a late 60's 350), but when I bolted the spare starter on, the starter gear didn't reach the flywheel, and just spun freely. I then looked on E-Bay and all the starters for sale there, have hte same bolt pattern as my spare:
http://cgi.ebay.com/ebaymotors/ws/eB...category=33576
The holes are straight across from each other, while the OEM starter on the TA had the starter bolt holes staggered. Do I have some kind of aftermarket starter on? Most importantly, do parts stores carry the starter with the staggered bolt pattern?
Thanks,
-Max
Old Apr 22, 2003 | 07:00 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
I may be wrong, but I think the OEM starters with the staggered bolt pattern are for a 168 tooth flywheels, and the ones with the bolt straight across were for the 153 tooth. Most aftermarket mini starters are straight across though.
Old Apr 22, 2003 | 08:31 PM
maksik7's Avatar
Thanks for the help. So, will I be able to pick a starter with a "straight-across" bolt pattern in an auto parts store?
-Max
Old Apr 22, 2003 | 10:10 PM
Odyssey's Avatar
Umm.. yeah ? I be if you ask for a starter for an 86 TA you'll get the correct one.
Old Apr 23, 2003 | 12:02 AM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
I scored a hi torque mini starter for cheap, it was the str8 bolt pattern that the 3rd gens need, but I had to shave some of the housing off of the starter, the flywheel was actually hitting it...I have never heard of anyone doing this but all is well now.
Frozer!!!
Jan 19, 2024 04:55 PM
mhatfield 14
Oct 24, 2015 07:48 AM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
sreZ28
Aug 14, 2015 07:48 PM
reiderz iroc
Aug 13, 2015 04:57 PM
