Spare Tire
Old Jul 25, 2000 | 09:08 PM
steve86bird's Avatar
Spare Tire
Alright guys were can I get a spare tire that won't rub against my rear brake calipers. I've been to three stores and I have specified 89 GTA WITH REAR DISK, and I now have three of the wrong spare tires. If anyone knows what I should be looking for I would greatly appreciate it.
Old Jul 25, 2000 | 09:11 PM
SGT SWEETPANTS's Avatar
I don't know if this will help at all, but you may want to try the junkyard instead. It would probably be cheaper and you could just look for a car with rear discs.
Pimpin' ain't easy.
Old Jul 25, 2000 | 09:22 PM
Jon92RamAirRS's Avatar
Check E-bay, etc for an aluminum spare. As far as I know the aluminum ones came on all the 1LEs and even some convertibles (conv. is heavier than t-type or hardtop, so aluminum was used to even up the weights). How bad is the wheel rubbing the caliper? Would a GM 1/8" spacer solve the problem? Just throwing out a few ideas.
Jon92RamAirRS
"Drive it Hard, or let someone drive it that will!"
MODS: 1LE front brakes, rear discs, aluminum driveshaft, 3.42 gears, Spohn LCA & PHR.
the_hamturdler
Sep 22, 2015 02:59 AM
HikoriYami
Sep 21, 2015 07:11 PM
F-body-fan
Sep 17, 2015 12:16 PM
2MNYMaros
Sep 15, 2015 11:36 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
