What mods should i do next??
Old Jul 25, 2000 | 10:27 PM
88FormulaWS6's Avatar
I want to get my car in the 14's in the 1/4 mile, so what mods should I do next to my car. I have only been to the track once and my best time is in my signiture, but I also had a 2.5 60 foot time on that run...and when I ran the 15.5 my car was running really hot and I didnt have the shifter ,fan switch , and thermostat in my car then. Are 14's really that far away???i think with the mods i just did and a good launch i can break into the 14's...what do you guys think...any comments are welcome.
88 Firebird Formula WS6
305 TPI 5 speed
B&m Ripper shifter
MSD Blaster coil
TPIS airfoil
Hypertech fam switch
TPIS 170 degree thermostat
15.5@91.18
Old Jul 25, 2000 | 10:54 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
Welcome to the board. I would do tthe exhaust first. If you can afford it go headers back or just get a cat-back system for now. Go 3" for sure. There will be a lot of different kinds out there to choose from and everyone on this board will have a success story to tell about their's. I went with Magnaflow and am happy with the sound not too loud at idle and just loud enough at wide open throttle. But there are a lot with Flowmaster and Dynomax that are very happy. You can also do the cheap and free stuff at the same time. Port your plenum, relocate you MAT, put an adjustable fuel pressure regulator in, gut your air box and put K&N's in there if you havent. That will pretty much get you started and I am sure others will join right in and tell you more. Any more q's just ask.
As the great Al Bundy once said.
"Hooter, Hooters yum, yum, yum, Hooters, Hooters on a girl that's dumb."
Old Jul 25, 2000 | 11:00 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
14's should only be a good launch, cooled down motor, and some decent traction away.
Put in an airfoil, K&N filter and exhaust and you should hit 14's no problem.
Old Jul 25, 2000 | 11:19 PM
Dan87IROC-Z's Avatar
Yeah, I agree that exhaust mods should get you into the 14s for sure. Start with a good cat-back Hooker and Edelbrock are the best bang for the buck, when you do the cat-back at the same time (cost permitting) a good high flow converter from Random Technology. The cat-back system ($260-$280) and the Random Tech cat ($212 from TPIS) should get you a good .5 seconds off your 1/4 ET. Also, since your car is TPI, dont forget to do the free mods, they are explained in detail in the tech section of this site. If you want another .3 to .4 taken off your 1/4 and have an extra $320 to spend, invest in a set of the Edelbrock TES headers.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Current Mods: Edelbrock TES Headers, Hooker Cat-Back System, Performance Resource Chip, 160* Thermostat, Accel 8.8mm Ignition Wires, K&N high flow air filters, gutted air box, gutted MAF sensor, Throttle Body Coolant By-Pass, Homemade Ram-Air, Falken ZIEX Z-Rated Tires.
1/4 mile times without chip:
Best ET: 15.7 @ 89MPH
Best Corrected ET: 14.5 @ 96MPH
starliner
Feb 9, 2016 08:18 PM
Quzyle
Oct 15, 2015 03:35 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
