HEI Problems
Old Jul 25, 2000 | 12:35 AM
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
HEI Problems
OK, I've posted a few times before about having problems with my HEI module. I finally figured out that the module itself isn't going bad, but just unplugging it causes something to reset. When it went out on me today I tried just unplugging one of the wiring harnesses that go to it to try and narrow down the problem. It ends up that I only have to unplug the two wire connector that goes to the coil to reset it. Could my problem just simply be a bad coil? Or is there something else? I want to hear your opinions before I throw parts at it. Thanks
Scott
88 GTA L98
14.389 @ 95.2 mph, 2.001 60'
In search of the elusive 1.9 60 foot time.
Old Jul 25, 2000 | 07:45 AM
TunedPort350's Avatar
Car: 88 GTA, 91 GTA, 92 T/A vert
Transmission: 6 speed & 700 r4's
Maybe you just have some bad wiring somewhere (a short to ground or a loose connection) and when you unplug things you are actually just moving the harnesses around a little and the short goes away for a while until things move around again. Next time try just moving the wires around a little without unplugging anything and see if it goes away again. Just a thought, but definately possible.
[This message has been edited by TunedPort350 (edited July 25, 2000).]
Old Jul 25, 2000 | 11:04 PM
Car: 88 GTA
TTT
Old Jul 25, 2000 | 11:21 PM
Vader's Avatar
Scott,
Have you measured the coil primary resistance? Does the resistance change significantly when the coil is hot?
Later,
Vader
"Some Body...Someone"
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
86CamaroDan
Sep 29, 2015 10:08 PM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
