new motor/oil leak
Old Apr 24, 2003 | 12:04 AM
JAKEDPLAYA's Avatar
new motor/oil leak
Alright guys..i have 1200 miles on my motor. I started my car up after sitting for the winter today, and when i moved the car i noticed a "spot" of oil.
(spot was the size of like bouncing a wet tennis ball on the pavement)
anyway, i looked under the car and there was a drip hanging from the oil filter, and one on the cover between the motor and trans.
What do you think/???/ When i bought the motor, The oil filter adapter was not there, so i told the place and they gave me one that was all oily and not new looking.
Thing oil filter adapter could be leaking or loose????
And bubbles constantly come from the hose that runs to my overflow tank, even when the cars cold..is this normal?
Old Apr 24, 2003 | 12:52 AM
Thirdgen86TA's Avatar
Look above the oil filter to see if there is any oil. I just posted something about mine leaking oil. I suspect the valve cover gaskets. Clean the engine really well and see if you could spot the leak. As for the coolant bubbling, did you let the air pocket out after you put new coolant in?
Old Apr 24, 2003 | 02:10 PM
JAKEDPLAYA's Avatar
when i put the new coolant in, i repeatedly filled the radiator until it stopped getting lower, covered it, then filled overflow to cold line once or twice until that stopped getting lower. Is this the correct way to get any air pockets out????
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
