Attn Vader
Old Jul 26, 2000 | 06:35 AM
shawn87gta's Avatar
Attn Vader
Vader,
You replied to a post last night concerning help with my ignition switch replacement. I am not replacing the cylinder lock, I am replacing the electrical ignition switch that mounts down on the steering column under the dash. There is a cable assy that is connected to this switch that locks the shifter until the ignition is in the on position. I can't see how to release this assy from the ignition switch in order to remove the switch.
Thanks for your help,
Shawn
Old Jul 26, 2000 | 07:21 AM
Kevin Irving's Avatar
Car: 1985 Trans Am
I'm not Vader and have no where near his experience, but I when I replaced my ignition switch 2 years ago I had to use a dremel to cut the plastic housing apart to get the park/lock cable out... you're replacing the switch anyway, so why not do it that way. IIRC you're supposed to find a little tab to push in to get the cable end to back out, but I for some reason that didn't work for me.
Also, make absolutely sure that you disconnect your battery while swapping that ignition switch out. I don't know if it had anything to do with it, but when I did mine, when I first started the car up after the swap I got a code 33 because I had fried the MAF sensor. Hope this helps.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, TB Coolant Bypass, Ported Plenum, Modified MAF, Cyclone Fuel Pump, JET Airfoil
Veiw my car at: http://www.geocities.com/transam85tpi/TransAm.html
R3500
Aug 24, 2015 09:05 AM
GTAlover
Sep 19, 2001 09:03 PM
