What degree thermo should I get??
Old Jul 24, 2000 | 02:54 PM
a1987formula350cu's Avatar
I got a stock 350 TPI. I thought I remember reading about 160 or 180 being better for a stock car. I can't remember which one.
This will make my car running cooler right? I hope it does b/c when I just start it up it runs soo much better. I get a 2nd gear chirp at 1/2 throttle and when it's warm i can't get it at full throttle.
1987 Firebird Formula 350[*]Stock except...[*]Cragar Street Stars
My Car Website w/ Pics
fyrebird350@hotmail.com
AIM/AOL Screen Name: FIREBERD350
Old Jul 24, 2000 | 03:05 PM
JP84ZROC
Guest
Posts: n/a
160* is what is used for best performance, but I would be careful using such a cool thermostat during cold weather(the o2 sensor needs to get to 650* to allow the ECM to go into closed loop). Also, the emissions equipment is designed to work best when the engine temp is 220* or so.
[This message has been edited by JP84ZROC (edited July 24, 2000).]
Old Jul 24, 2000 | 03:07 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
For your climate, use the 170 or 180. Just changing the thermostat alone probably won't make it run cooler. Get an adjustable fan switch, and that combined with the thermostat should do the trick.
Old Jul 24, 2000 | 03:24 PM
How much are the fan switches? CAn I get them at Pep Boys or Autozone? Also are the thermostats from Pepboys good? or should i got w/ one from jegs/sumitt?
Old Jul 24, 2000 | 03:41 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
I've seen an adjustable fan switch at Pep Boys before. It is not the switch that screws into the cylinder head, but the kind of switch that you stick the probe into the radiator fins. Get an adjustable one. Should be around $30-40 bucks.
Thermostats all work the same, but don't know if any flow more than others. I've used the auto store thermostats with no problems, but the speed shops always sell 'high flow' thermostats for twice the price.
This is the best info that I've seen on keeping your f-bod cool. https://www.thirdgen.org/tech/cool.
Old Jul 24, 2000 | 09:24 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
i use 160 robertshaw t stats in about everything and i live in michigan. never had a problem getting into closed loop.
Old Jul 26, 2000 | 11:53 AM
that link don't work anymore
RedLeader289
May 28, 2019 01:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
jaridjohn
Oct 5, 2015 07:01 AM
ironbmt
Sep 27, 2015 06:00 AM
