Lets talk about LT1 camshafts
Hey guys I have a 89 formula TBI car with a 355, My engine builder installed a LITTLE BITTY cam its like 414 lift 210@50, but my boss has a cam from his LT1, will this cam work in my car? If so will my Z28 valve springs work for this cam? Will I have to get a custom chip burned for the cam or will stock one work? Does anyone know what the specs are on the cam, it come from a 96 z28? Sorry about all the questions and thanks for the help.
Just made my intake to fit a 454 TBI and found some 65psi cop car injectors, this will be installed tomarrow, Hope it works
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
An LT1 cam would be pretty lame IMHO for a 355.
Actually your cam has more duration (read higher RPM HP) than the LT1 cam.
Here's a chart that Vader posts here quite a lot. I must say though that the cam I have (LT1 cam) isn't on this list.
The only way to tell for sure what you have is to break out with the dial caliper and/or a dial indicator as well as a degree wheel.
BTW, I spec'd mine. It's out of a '96 also. It reads as follows...
LSA - 116
Int - .450"
Exh - .459"
Int dur @ .050" - 203*
Exh dur @ .050" - 208*
As you see it has more lift than yours, but not quite as much duration, which is atypical of a roller cam.
LSA - 116
Int - .450"
Exh - .459"
I would do a search in the TBI board for
LT1
or
LT1 Cam
or
LT1 Cam Install
You're sure to get some results.
LT1
or
LT1 Cam
or
LT1 Cam Install
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
yes it will work no problem. since you have a roller motor it will work. take the old one out and slap the new one in.
gixxer92
May 18, 2017 11:20 AM
88SS6SPEED
Nov 11, 2015 07:05 AM
the_hamturdler
Sep 30, 2015 12:50 PM
