HELP! Car stumbles at idle and while driving!
Old Jul 25, 2000 | 06:23 PM
Z28Freak's Avatar
From: Tacoma, WA Age: 30 Car: '85 Z28 Marital Status: Married
This just started yesterday. My car will idle just fine then it will kinda hiccup and the rpms will drop real low for a second then back to normal idle. This occurs every two to three seconds. It also happens while driving. I hope my MSD box isn't going bad! What could this be?
'85 Z28 - black with gold trim - TPI 305 (pre-peanut cam 215hp) - Accel Super Coil - Accel 8.8mm wires - Morroso trans cooler - MSD-6A - Flowmaster exhaust - high flow cat - K&N filters - smog delete - 3.23 rear
'94 Camaro SC - medium patriot red metallic - 3.4L - Dynomax muffler - Z28 wheels
Sir John; Order of Knights of the Mighty Cascade Crew
Old Jul 26, 2000 | 12:23 AM
JP84ZROC
Guest
Posts: n/a
Whats your fuel pressure? your fuel pump may be about to kick off.........
"84Z28/'91 305TPI comp cam flowmaster TB coolant bypass/shutoff valveto heater core MAT relocated Ram-Air(home-made) gutted air-box IROC ground effects/wheels GY245/50's 700R4 superior shift kit/ corvette servo(excellent shift kit BTW) Rebuilt engine and transplanted it myself.
LOW performance people should drive low performance vehicles!
Old Jul 26, 2000 | 02:38 AM
Z28Freak's Avatar
Thanks for the reply, but I figured it out. Its the f*cking Mass Airflow Sensor! This is the second one in two years thats gone bad!
Old Jul 26, 2000 | 02:43 AM
Mike92's Avatar
Can you convert to Speed Density? I don't know the answer but if you can, you may want to if your climate or car for some reasons makes MAF sensors malfunction prematurely.
Old Jul 26, 2000 | 04:48 PM
Z28Freak's Avatar
I would love to change to speed density, unfortunately that would involve a computer and harness swap and I don't think I'm up for that.
Actually, I think I fixed the problem. I did the TB coolant bypass and ran the heater hose under the MAF sensor. It was right up against it and I think it was heating it up. I moved the hose down a little and the problem seems to have gone away. Keep your fingers crossed!
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
86IROC112
Aug 17, 2015 02:00 PM
squiggy2
Aug 9, 2015 09:30 PM
