A/C Warm/Cold
Old Apr 25, 2003 | 05:49 PM
SgtSkip's Avatar
A/C Warm/Cold
My A/C can be cold and it can be warm...why? Charge? If it's the charge, can I buy the Walmart R134 conversion kit and "just" change it over??
Old Apr 26, 2003 | 10:46 AM
Vader's Avatar
Sarge,
Chances are, your charge has slipped.
You could retrofit R=134A, but you'll probably be disappointed with the results unless you make a lot of modifications, like larger coils, a different orifice tube, and don't mind the lack of cooling at low RPMs.
You might be better off with R-414 or some other type of drop-in replacement for R-12. R-12 move more heat energy than R-134A, plain and simple. R-414B move more heat than eother one, and will really wake up your AC sysytem.
Of course, you need to make sure the AC system is not short-cycling because of a high pressire issue, like a plugged condenser, debris over the front of the condenser, or between it and the radiator, or debris that is sucked into the evaporator coil. I'm not sure about your area, but around here, leaves, grass clippings, dust, insects, and weed seeds can clog up an evaporator in only a few years.
A quick pressure test of the system should identify your problem(s). I'm guessing that you might know someone who has a gauge manifold.
Old Apr 26, 2003 | 11:57 AM
SgtSkip's Avatar
I haven't heard of R-414. Do you have to be certified to purchace it like you do for R-12? If not, do you need to purge the R-12 first? I'll get with the auto hobby shop on base to see if they have the gear to test the system.
As far as the evaporator goes, I wouldn't be surprised if it's clogged. How do you get the cover off to clean it out? I haven't been able to find a good way just yet.
Old Apr 26, 2003 | 12:28 PM
Vader's Avatar
Sarge,
R-414B is a CFC replacement that can be charged RIGHT OVER the existing R-12 charge. It's compatible and miscible with R-12 and all of its oils, so there's no need to purge and evacuate unless the system has completely dumped of is contaminated from a compressor failure. R-414B requires certification to purchase it, but I wouldn't be surprised if a place that had a manifold and lots of refrigeration equipment already had some R-414B on hand in 25# cylinders (like my garage).
As for cleaning the evaporator, I don't know of a good method - it's an all-day sucker, for sure. If it's clogged, it'll be one of the better days you'll spend under your hood.
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
BLK87Z
Sep 18, 2015 11:29 PM
Mdenz3
Sep 17, 2015 08:36 AM
