Which Lt1 cam to use?
Old Apr 26, 2003 | 05:06 PM
mich2112's Avatar
Car: 1991 Z28
Engine: 350 L98
Axle/Gears: G92 - 3.23
I'm building a l98 350 with stock Iroc heads and about 9.7:1 compression. I want to use an Lt1 cam and I want to know which year cam is best for my combination. I have a 700r4 and will be running 3.27 gears.
94-95 LT1: Duration 203/208 Lift 450/460 Lobe sep 116
96-97 LT1: Duration 205/207 Lift 447/459 Lobe sep 117
As you can see there are almost the same except for the lobe sep.
Here is the stock L98 cam specs:
Duration 202/206 Lift 403/415 Lobe sep 115
Basically the Lt1 cams have more lift and a few more degrees of lobe seperation. What will that do for my engine?
Thanks, Mike Jones
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
L0tuS
Sep 4, 2015 11:16 PM
Strick1
Sep 4, 2015 07:11 AM
