pont stroking a 400 to 455
Old Apr 26, 2003 | 07:06 PM
TheViper's Avatar
Car: '84 Z28
Transmission: th2004r
if i start with a pontiac 400 from a 78 T/A can i use the whole rotating assembly from a 455? or do i need to use the 455 rods with 400 pistons?
Old Apr 27, 2003 | 11:38 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
You need to have the 455 crank turned down to the 400 main size. Then you could bore the block to the 455 pistons stock being +.030" compasred to 400 bore. Then you could use the 455 rods and pistons.
Old Apr 27, 2003 | 07:20 PM
TheViper's Avatar
Car: '84 Z28
ok, thx, the pistons would be stock for the 455 at .030 over on the block right?
Old Apr 27, 2003 | 08:23 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Stock 455 pistons would be +.030" for the 400.
Hotrodboba400
Dec 10, 2019 07:07 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
dusterbd
Sep 29, 2015 08:40 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
