trick flow heads and felpro 1094?
Old Apr 26, 2003 | 09:15 PM
slayer2000's Avatar
Car: 1990 GTA
Transmission: manual/t56
Hey guys,
anybody usiung trick flow or other aluminum heads and felpro 1094 steel shim gasket? I've used these gaskets pretty sucsessfully with iron heads but any have problems with alum? will the heads be indented by these gaskets? Any info would be great.
Old Apr 27, 2003 | 05:55 PM
slayer2000's Avatar
Car: 1990 GTA
nobody has any info? I did a search but didn't really come up with anything
Old Apr 27, 2003 | 07:11 PM
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
Use normal head gaskets. The steel shim gaskets are only good if you are trying to bump up a REALLy low compression motor, but if you have a motor already making 9:1 or more then its really not worth it. Maybe worth a few HP, nothing you'd feel, and all you'd end up doing is detonating the **** out of your motor. And FYI I found a MUCH cheaper alternative to the fel pro 1094s. Go to your local autostore and tell them you want steel shim head gaskets for a 1969 chevy pickup truck. They are the SAME exact thing minus the coating. Then all you do is use the Copper spray gasket and spray both sides.........and waalllaaaa fel pro 1094 except the truck steel shim's cost like $9 each! I would really go with a normal composite if I were you though. My friend had a motor built similar to mine and with a 100 shot of nitrous he blew a leak in his 1094s.
Old Apr 30, 2003 | 03:55 PM
slayer2000's Avatar
Car: 1990 GTA
Thanks for the info. I don't think detonation will be a problem on aluminum heads. It's just I already had these gaskets in the garage so I wanted to use them. I like the trick with the truck gaskets. That would be a good way to go. If anyone else has any more info I'd like to here from you.
gta90
Sep 15, 2015 04:00 PM
Mickeyruder
Sep 2, 2015 02:45 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
