Can a Coil be Mounted Upside Down??
Old Apr 27, 2003 | 07:00 AM
david auster's Avatar
Car: 1992 Camaro
Engine: 350 miniram
I have a miniram on my engine and they don't seem to have a provision to mount a coil to it so my next best thought is to just mount it on the lip on the firewall, kind of like how the MAP is mounted on the TBI cars. The coil is the direct replacement MSD part#8668 for the small cap dist. that have the remote coil. Would it be a problem if its mounted upside down? How about the MSD 6AL I plan to install after any particular position it needs to be in?
Old Apr 27, 2003 | 07:14 AM
ede's Avatar
ede
i've mounted coils up sdie down, and side ways, never had a problem. not sure it it's the 100% best way to do it but it's worked for me.
Old Apr 27, 2003 | 08:16 AM
Vader's Avatar
It's more important to keep the primary wiring as short as possible. Even an oil-filled coil can be mounted upside-sown.
Old Apr 27, 2003 | 08:26 AM
Car: 1992 Camaro
Engine: 350 miniram
Thanks guys, I was pretty sure I could do that but just needed a little reassurance it was alright. I'm going to mount it on the firewall lip right next to the distributor so the primary wiring should be as short as any stock setup.
J-money
Jan 4, 2019 09:45 AM
FormulasOnly
Sep 6, 2015 10:42 AM
SG91camaro
Sep 5, 2015 10:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
